high idle problem
Old Feb 2, 2009 | 09:09 AM
scotchy46088f250's Avatar
scotchy46088f250
high idle problem
i have a 1988 f250 with a bb 460 efi and i was wondering if any one knows how to fix it? i already used a vacum gage and vacum is fine theres no leaks around the intake manifold nothin and it dosent go down when you use the the throttle or idle adjusting screw.
Old Feb 2, 2009 | 12:00 PM
Lazy K's Avatar
Lazy K
I would think you either have a vacuum leak somewhere or you need to clean the Idle Air Control valve or you possibly have a bad Throttle Position Sensor. You should not mess with the idle screw as this can throw your TPS off. Have you a Check Engine Light on?
Go to fordfuelinjection.com and you will see how to clean the IAC valve, read about the TPS and see how to pull any stored error codes. However check for a vacuum leak first. Just my opinion. Hope this helps.
Old Feb 2, 2009 | 12:39 PM
scotchy46088f250
ok the and the vacum is reading normal and the check engine light is not on .
Old Feb 2, 2009 | 02:27 PM
Lazy K's Avatar
Lazy K
Even if the CEL is not on you may have stored codes, might be worth checking. A gauge may not detect a small vacuum leak. If no leak then it would point to the IAC or TPS. I would clean the IAC and check for codes and as the idle screw was moved you may have to adjust the TPS as well as test it.
Old Feb 2, 2009 | 04:23 PM
scotchy46088f250
ok thanks and what would i need to check the codes with
Old Feb 2, 2009 | 06:01 PM
scotchy46088f250
and when we moved the idle screw nothing moved nothing happend to the throttle componets and what is a good ford truck parts web site that has everything?
Old Feb 2, 2009 | 06:04 PM
quisp-n-quake's Avatar
quisp-n-quake
FORDFUELINJECTION.COM
Shows you how to pull the codes with a simple paperclip- i do it all the time-'88 f150
-A Haynes manual comes in handy for explaining the codes, but I guess you could get the codes online too.
Old Feb 2, 2009 | 06:06 PM
quisp-n-quake
LMC TRUCK .com- good parts supplier- and they show schematics of everything-good luck.
Old Feb 2, 2009 | 09:07 PM
scotchy46088f250
yea they do i have there book but they dont have any fuel rails
Old Feb 3, 2009 | 10:43 PM
Dre82s's Avatar
Dre82s
What is the best way to check for Vaccumm leaks?
Hey guys how are you all doing, My truck has a high idle problem, it stays between 1200 to 1500 at idle, I have replaced the EGR and well as my TPS, how ever my throttle screw is back out all the way, how do reset the positioning of the screw as well as the the TPS. But my two biggest question are, how do I check for vaccum leak, and how do I take my intake off?
I really want to get allt he built up off the intake as well as replace the gasket truck set for sometime,
1988 F-250, 5.0, 5 speed MAZDA, 4X4, 170K, 3.55 WITH 31' TIRES.
Old Feb 5, 2009 | 09:37 AM
scotchy46088f250
ok and if the codes dont fix the tps and iac could it be the map sensor or somthing else?and i need to get a fuel rail
kipdog
Modular V10 (6.8l)
Jan 25, 2011 05:36 PM
cpettymore7777
Mar 26, 2009 09:13 PM
grizz3000
Dec 21, 2006 12:09 AM
bigfrank
Jun 4, 2004 12:46 AM
akmud
43
Mar 5, 2004 01:34 PM
