need help please im lost
Old Feb 1, 2009 | 06:54 PM
jdog_kustoms's Avatar
jdog_kustoms
Unhappy need help please im lost
i have a 1980 f350 with a 400 in it it has been running for about 15000 miles the other day after i replaced the blow out intake gasket i was test driving it and it just shut off sounded like i turned the key off and it would not restart i had it towed to my house and started to work on it i had fuel and spark from a new distributor but it was blowing fuel out of the fuel bowl vent when i cranked it over the motor is still in time i pulled the front cover to double check and i pulled the intake and the gasket looked good on removal my compression testor shows about 25 psi on each cylander so im thinking my guage is shot but im lost on what it could be
it does have 2 different heads one is casting number d3ae g2b the other is d5ae a2a this one looks to be egr the d3ae is not egr i am running a weiland dual plane intake procomp gear drive up front and the summit sum-5200 cam with lifters and comp pushrods i did notice the back pushrod on each side is bent but one is intake one it exhuast
any help would be greatly appriciated
Old Feb 2, 2009 | 02:45 PM
jdog_kustoms
no body has any ideas
Old Feb 3, 2009 | 07:37 AM
MBDiagMan's Avatar
MBDiagMan
If fuel is coming out the vent the needle and seat is stuck.
Old Feb 3, 2009 | 03:27 PM
jdog_kustoms
it is spraying out like its pressure ising the intake and i found out i guess my rings or pistons are shoot if i pressureize the cylender you can here is spraying in the crank case
Old Feb 3, 2009 | 08:47 PM
fordeverpower's Avatar
fordeverpower
you are going to have a certain amount of leakage with a leakdown test. You say you have fuel and spark, but that it is leaking from the vent. That would be a needle and seat or float problem.
Its hard following all your posts, and i don't think your head castings are a great issue. I would fix the carb problems foremost, and then check timing and gear drive( procomp is junk).
Old Feb 3, 2009 | 08:51 PM
jdog_kustoms
ive tryed 2 carbs they both blow fuel out about 8 to 12 inches it cover the under side of my hood it is in time ive checked it a hundres times and there is no fuel getting to the plugs
Old Feb 4, 2009 | 08:31 AM
garypettengill's Avatar
garypettengill
I know you said your timing is on the money. You mentioned a couple of bent push rods. Pop off one of you valve covers and watch the lifters while you crank the engine. To me it sounds like your cam may have failed.
Old Feb 4, 2009 | 09:10 AM
MBDiagMan's Avatar
MBDiagMan
Find and fix your fuel spray issue before doing anything else.
Old Feb 4, 2009 | 02:50 PM
jdog_kustoms
i have the front off the motor and both valve covers off the valves are all working good and i thought it jumped time or messed up cam but it is ok
i am trying to figure out the fuel spray that is the problem but im lost on trying to find the problem
Old Feb 4, 2009 | 03:09 PM
MBDiagMan's Avatar
MBDiagMan
Can you SEE where the fuel is coming from? Is it making a stream anywhere?
Take the carb off and turn it upside down. Then pressurize the fuel inlet with a few psi. (I get it clean and pressurize it with my mouth) When pressurized it should hold pressure. If it is then the needle and seats are holding. If it doesn't hold pressure while upside down, the problem is needle and seat related.
Old Feb 4, 2009 | 06:07 PM
jdog_kustoms
its not fuel pressure issue i have and electric fuel pump it works fine when i run it the only time it sprays fuel is when you crank over the motor like you pressurizing the intake some how and it is pressurizing the carb
Old Feb 4, 2009 | 06:33 PM
jdog_kustoms
any one have issues with summit 5200 cam
Old Feb 4, 2009 | 07:15 PM
TMI's Avatar
TMI
Have tried taking a cranking compression test yet?
jdog_kustoms
could running a sum-5200 cam with stock valve springs a big no no with coil bind
Old Feb 4, 2009 | 07:17 PM
jdog_kustoms
yeah its only 30 psi
