how do I check the MAP sensor??
Old Jan 31, 2009 | 05:17 PM
piotrsko's Avatar
piotrsko
On my boy's ranger, when I disconnect the hot air stove vacuum source that is a "T" fitting with the MAP sensor and produce a vacuum leak, it stops being really rich no with idle speed increase.
no codes except for 11 / 11
The manuals I have say I should have a MAF sensor, but there isn't anything there where it should be.
question #1:How do you test the MAP?
question #2: what years had MAP sensors?
BTW make tag says build date of 6/86, model tag on door frame says model year 87, and DMV says it is an 88 because it has a "J" in the VIN
Old Jan 31, 2009 | 05:42 PM
pawpaw's Avatar
pawpaw
For MAP testing check out Ford MAP/BP Sensor Operation and Testing
02FX4Dude
Nov 1, 2018 05:19 PM
Orcburner
Jul 21, 2010 01:21 PM
mh34444
Bronco II
May 14, 2007 08:48 AM
CPE
Jun 22, 2003 06:39 PM
