MAF conversion: MAP vs BP sensor?
Old May 16, 2005 | 07:32 AM
02FX4Dude's Avatar
02FX4Dude
Question MAF conversion: MAP vs BP sensor?
Hi All,
I have a "junkyard" MAF conversion on my 87 F150, 302. The generally accepted procedure with the MAP sensor has been to disconnect the vacuum from the sensor and leave the wiring intact, thus making it the BP sensor for the Stang puter.
However I'm now getting some conflicting information. I was checking, among other things, how BP sensor readings affect AF ratio on fordfuelinjection.com. The site states the MAP sensor and BP sensor are different, even though they look alike. Sure enough, the charts (on the website) do show a different calibration.
Being brief, I crunched some numbers and find at 102kpa barometric pressure(currently in my hometown) a MAP sensor should give 238Hz, while a BP sensor will put out 161Hz. So using the MAP sensor as a BP sensor would make the Mustang computer think the pressure is at 185kpa.
Question is: should I worry about this or just get back to what I'm supposed to be doing here at work.
You out there EPNCSU2006?
Thanks
Brian
Old May 16, 2005 | 08:38 AM
fefarms's Avatar
fefarms
102 KPA is sea level, more or less.
185 KPA is well above normal atmospheric pressure. The computer may wonder what the car is doing at the bottom of the lake -- just kidding, the computer will probably just quietly accept "185KPA" as the same value as "sea level".
I suspect folks re-use the MAP sensor in this fashion because it provides a time-varying signal and the computer doesn't set codes. The net effect is to disable the BARO function -- the computer will always think the vehicle is at sea level.
The BARO function doesn't do all that much with a MAF sensor computer anyway. I think it is primarily to adjust mixture ratio for starting. In Waukesha you are far away from places like Leadville, CO -- the kind of elevation where the BARO sensor might actually make significant changes in how the computer controls the engine.
Old May 16, 2005 | 10:24 AM
EPNCSU2006's Avatar
EPNCSU2006
I used the truck MAP sensor at first, but later changed it to a BAP sensor from a mustang and noticed no difference in how the engine ran.
Old May 16, 2005 | 10:37 AM
02FX4Dude's Avatar
02FX4Dude
and
OK, that's what I was wondering was how much the sensor was used for calculating AF ratio while driving. If I can't notice it in performance or MPG I'll leave it.
Thanks.
Brian
Old May 16, 2005 | 09:22 PM
EPNCSU2006's Avatar
EPNCSU2006
To be honest, I don't really know why Ford used the BAP sensor with a mass air sensor anyway. Startup seems to be the best explanation, when the mass air meter would read low. Otherwise, the MAF should account for changes in density due to elevation or otherwise.
Old Nov 1, 2018 | 03:28 PM
jtab's Avatar
jtab
I realize how old this thread is, but it is exactly what I was looking for, so I'm reviving it.
My pickup, a 1993 F250 460, was running very rich, and I thought a MAF conversion would help with that. Now, after my MAF conversion, my pickup is still running very rich.
I'm suspecting the MAP sensor. So if I'm going to replace the sensor anyway (after i do some o-scope testing) am i better off replacing it with the same MAP sensor or a true BAP sensor?
Thanks,
-Joe
Old Nov 1, 2018 | 05:06 PM
Conanski's Avatar
Conanski
What PCM did you use for your MAF conversion? If it was a truck PCM then your MAP sensor no longer matters because the truck MAF PCM doesn't use one.
Old Nov 1, 2018 | 05:19 PM
jtab's Avatar
jtab
It was a kit from Fiveology using a '94 or '95 5.0 Mustang ecu.
- Joe
Bossman7121
21
Jul 3, 2010 11:15 AM
FordPerf300
25
Dec 29, 2007 03:46 PM
ernesteugene
33
Nov 2, 2007 12:25 AM
ernesteugene
30
Oct 13, 2007 02:28 AM
ernesteugene
35
Oct 3, 2007 07:53 AM
