underbody paint
Old Jan 31, 2009 | 10:42 AM
crazer42's Avatar
crazer42
underbody paint
is there a special paint that i can get to paint the axles, leafs, and frame i see old trucks that are nice and black, and mine is al faded and a bit of rust just wondering how to paint thanks
Old Jan 31, 2009 | 11:13 AM
rmilchman's Avatar
rmilchman
You could try some POR 15.
-POR-15 Inc.
Old Jan 31, 2009 | 12:38 PM
jeff7825's Avatar
jeff7825
Undercoating. Should be able to get it in a spray can at your local auto parts store. I put some regular black spray paint on mine and it is holding up well.
Old Jan 31, 2009 | 01:34 PM
guitarpicr's Avatar
guitarpicr
I used the por-15. It is holding up good also - Clean and prep are the important part ,IMO.
Old Jan 31, 2009 | 01:41 PM
guthrie&co's Avatar
guthrie&co
I have heard that the undercoating will trap moisture. I don't really know for sure. I usually do mine once a year or two with just flat black spray paint. I found that the undercoat builds up and kinda looked like you over painted it several times. it took away the detail around the hardware and made the hardware difficult to use again. I couldn't get a socket ocer a nut or bolt ect due to the build up
Old Jan 31, 2009 | 04:35 PM
m300636's Avatar
m300636
Underbody paint
I used POR15 on my last truck...under the dump body, frame, springs, etc.
It has held up tremendously!! Can't say enough good things about it. Follow the directions, I pressure washed the truck, used an electric wire brush on all the loose stuff and pressure washed it again and let dry real good. Never did use the cleaning solution they recommeded but did give it 2 coats as recommended. Stuff is tough as nails...if you get any on your skin remove immediatly or you will be wearing it for a very long time.
Well worth the price and effort..bought it online!
SouthernBlues
Aug 18, 2015 05:08 PM
White76
Paint & Bodywork
Mar 5, 2014 05:11 PM
shawn11762010
Jul 15, 2012 11:15 PM
AmnStroker
Paint & Bodywork
Feb 16, 2010 10:19 PM
yamaha4400
Paint & Bodywork
Jul 28, 2004 07:07 PM
