Do a f-350 brake upgrade!!!
Dirty D, I agree with the upgrade. I've already done the 84 Bronco, and now that the rear cylindrs and MC on the 78 Bronco are leaking I plan to do it also. The booster is a direct bolt-in, very simple. I had to use a different size fitting on one of the line (rear, I think) for the MC on the 84 F-350 parts, but I was replacing all the lines anyhow. JSM84
Here's a great tech article on the 78/79 Bronco upgrade:
https://www.ford-trucks.com/article/...d_Broncos.html
I'm looking into this brake upgrade since my calipers are seizing and my brake booster is going out. (What better time?) I had a question on the fitment of the lines to the Thunderbird calipers with the TTB. From what I've heard, there's clearance issues between the calipers and the steering knuckle and some people have a bit of grinding to do. How did you run a brake line to the calipers on the '84?
I ran a single line to the center of the engine crossmember ,then a braided steel line to the axle to a tee. From the Tee, i ran hard lines out to both knuckles, then standard hoses to the calipers. I plan to swap out the standard hoses for some more braided steel hoses that i just ordered, with a -AN adapter on the calipers. JSM84
T-Bone_600
10-27-2004 08:04 AM
