Water pump/coolant filter
Old Feb 3, 2009 | 04:25 PM
  #31
superduty4x4's Avatar
superduty4x4
So a question... with a 203 stat running $37 now is it really worth the money spent over a stock replacement stat, or save the $ and just run the stock stat?
Old Feb 3, 2009 | 04:41 PM
  #32
F250_'s Avatar
F250_
Theoretically, the higher temps allow the engine to run more efficiently, which is the only place where you can find actual "payback" for upgrading to the 203* stat. Problem is that I don't think anyone has ever really tried to quantify it, and have simply reacted to the theoretical scenario and paid for the "upgrade"... which is exactly what I've done myself as well.
I just need a weekend, hopefully this one coming up, to do the system flush, coolant change, filter installation, IC replacement, replace both upper and lower radiator hoses, and new stat/housing installation... I'm going to get it all while I'm in there at one time.
Old Feb 3, 2009 | 04:45 PM
  #33
PwerStroke99's Avatar
PwerStroke99
thats lame!!! LOL Did u get that truck figured out that u called me about the other day?
  #34
superduty4x4
Pete- I know what the 203 stat is "supposed" to do but I'm not much for spending $ on something if there is no benefit to doing so. If the 203 stat is all talk and no go then I'd rather just get a stock replacement stat and save the $. Are you going to go with ELC coolant, or standard stuff?
Old Feb 3, 2009 | 06:33 PM
  #35
jdecker88's Avatar
jdecker88
Isn't it also suppost to warm up your heater in the truck as well on very cold days?
Old Feb 4, 2009 | 03:27 AM
  #36
Stewart_H's Avatar
Stewart_H
Originally Posted by superduty4x4
Good info in here, some reps to come for some of you. Somewhere it was mentioned that the ELC is not preferred for early birds- any particular reason?
I'm not 100% sure on this so please be diligent and do more research using Gooch as the user name over at the "other" diesel site, but IIRC from when I did my research about 4 years ago, the pre-'99.5 PSD's have different seals and gaskets than the post '99.5 PSD engines, and the ELC's don't do well with the early style builds.
Stewart
Old Feb 4, 2009 | 03:41 AM
  #37
Stewart_H's Avatar
Stewart_H
I just learned that Gooch has updated the very old flush procedure I recently posted.
Below are his latest and most thorough instructions, with hyperlinked pictures:
You'll need the following:
  • 4 gallons of anti-freeze concentrate.
*Tip* Do not use 50/50 pre-mixed coolant. After flushing, residual water will remain in your engine and cooling system that you can't get out. Therefore, adding pre-mixed 50/50 will further dilute the solution and yield a weak freeze point, along with a low level of corrosion and cavitation inhibitors. Your cooling system holds approximately 8 gallons. Adding 4 gallons of concentrate after flushing, and then topping off with distilled water, will ensure optimal protection.
*Tip* International who made your engine, and who's engine your Ford cooling system was designed around, recommended a Heavy Duty Extended Life Coolant (HD ELC) for all 2/2/99-up built engines (SN 940614-up). These are generally red coolants with operation lives of 300K-750K miles/6-8 years, depending on brand. They are very robust and require no maintenace or additives. Popular brands include International's Fleetrite ELC, Shell Rotella ELC, CAT ELC, Chevron Delo ELC, Peak Final Charge, Prestone Heavy Duty ELC, Zerex Extreme Heavy Duty, etc.
*Tip* Due to International's compatibility tests, all pre-2/2/99 build engines (pre-SN 940614) should use a conventional coolant with the addition of SCA (or a pre-charged conventional coolant already charged with SCA). Most conventional coolants will be green, "low-silicate" and meet ASTM D4985. There are too many brands to list. They will require the addition of a supplemental coolant additive (SCA) at initial fill and maintenance of that SCA thereafter. Most pre-charged conventional coolants will be pink, purple, or blue and meet ASTM D6210. These coolants do not require an initial dose of SCA, but will require SCA maintenance thereafter. These are coolants like Peak Fleet Charge, Prestone Heavy Duty, Zerex Precharge, Shell Diesel Ready, Fleetguard Fleetcool, Fleetrite Fully Formulated, and so on.
*Tip* Do not use "All Makes - All Models" coolants, or "Universal" coolants. They will not meet the needs of your diesel engine.
  • SCA (if using conventional non-charged coolant). Amount depends on the SCA maker (usually 3-4 pints).
*Tip* Either a Nitrite only DCA-2 SCA or a Molybdate/Nitrite DCA-4 SCA will work.
  • Up to 20 gallons of distilled water
*Tip* Tap water contains undesirable minerals, chemicals, and pH. If your tap water is good quality, you can do fewer distilled water flushes.
  • A Prestone flush kit with 5/8" "T". HERE is a photo of a NAPA #720-1286 5/8" flush kit with "T".
*Tip* The "T" regulates and restricts faucet flow. Directly connecting to your faucet without one of these "T's" could damage your cooling system.
  • 1-1/2 foot of 5/8" hose (to go on flush "T").
  • A new thermostat gasket. OEM Part# F4TZ-8255-A
*Tip* Now might be a good time to consider replacing:
Thermostat (OEM Part #F6TZ-8575-EA)
Thermostat housing (OEM Part# F81Z-8592-AA)
Upper radiator hose that goes around serpentine belt (OEM Part# F81Z-8260-CA)
Lower Radiator hose (OEM Part# YC32-8286-CE)
Degas bottle cap (OEM Part# F6DZ-8100-A)
New coolant filter (if you've added one)
Any hose clamps that you feel should be replaced.
Tools needed:
  • 3/4" wrench for drain plug
  • 8mm socket with rachet and extension for thermostat housing bolts
  • 1/4" socket driver for block plugs
  • Pliers for hose clamps
  • Torque wrench to re-torque thermostat housing bolts
  • Emery cloth to clean thermostat housing and hose connections
  • Bucket and suitable catch containers.
  • Funnel
*Tip* A children's small plastic wading pool works good for a catch container. Some fit between the front wheels perfectly.
Flushing procedure:
Park truck on level surface. Allow to cool.
Remove degas bottle cap slowly (be careful if hot).
Use 3/4" wrench to losen radiator drain valve (bottom left-hand driver's side). Drain into suitable container. Expect at least a 5-gallon bucket-full.
Remove lower radiator hose (at radiator) and drain any sediment and/or coolant from radiator and hose into container.
Remove driver's side block plug with 1/4" socket wrench driver, and drain coolant into suitable container.
Remove passenger's side block plug with 1/4" socket wrench driver, and drain coolant into suitable container.
*Tip* This is best done without an extension on the wrench, working under the truck from the top rear side of starter - no need to remove starter.
Re-install both block plugs finger-tight.
Re-install lower radiator hose temporarily.
Close radiator drain valve.
Remove thermostat housing and thermostat.
Re-install thermostat housing without thermostat, using old gasket (it's ok if it leaks a little while flushing and running engine).
Remove heater hose at passenger's side coming off the engine (just below intercooler tube).
Install that heater hose to one end of the 5/8" flush "T".
Install 1 1/2 foot of 5/8" hose to other end of flush "T", Like this.
Install the remaining end of the 5/8" hose to fitting where the original hose was removed from the engine.
*Tip* You could permanently install the flushing "T" in the heater hose if desired. The heater hose removed in this procedure is the one consistent with what you'll find on the flush "T" directions. However, you could install the "T" on either heater hose.
Install garden hose onto flush "T", noting the direction of flow stamped on the "T".
Turn garden hose on until clear water (no green tint) runs (backflushes) out of top of degas bottle. This will take several minutes.
With hose still on, start and run engine for a couple of minutes, again until water coming out of degas bottle is clear (no green tint). Minor water leaks and spray from fan are normal.
Turn engine off. Turn garden hose off.
Drain radiator at drain valve, remove both block plugs, remove lower radiator hose.
Remove flushing "T", the extra 5/8" hose, and reinstall the original heater hose back onto engine.
Close radiator drain valve, reinstall and finger-tighten both block plugs, reinstall lower radiator hose (permanently).
Fill system with distilled water until the degas bottle is full.
Run engine a couple of minutes.
Drain radiator at drain valve, remove both block plugs.
Close radiator drain, reinstall and finger-tighten both block plugs.
Again, fill degas bottle with distilled water.
*Tip* You may decide to flush with distilled water one more time if your tap water is extremely bad.
Close radiator drain valve permanently. Do not over-tighten.
Install both block plugs and tighten permanently and firmly. Sealant can be used on the plugs sparingly, but it is not necessary.
Install thermostat and new thermostat gasket. If reusing the thermostat housing, use emery cloth to clean any rust/corrosion before installing.
Carefully torque the thermostat housing bolts to a maximum 15 ft-lbs. Do not over-tighten.
Add 4 gallons of anti-freeze concentrate to the degas bottle.
If using SCA, add it to cooling system per SCA manufacturer's instructions (usually 3-4 pints).
Add distilled water to finish filling the system until the degas bottle indicates between min/max.
Replace degas bottle cap.
Rinse off any coolant from engine and underbody of vehicle.
Turn in-cab heater valve all the way to "hot". This will help you determine if the thermostat is operating or if there is air left in the system.
Run engine (or drive truck for faster heating), until thermostat opens and hot air is felt through heater in cab. Periodically check coolant level adding distilled water as necessary. If heater does not get hot (or stay hot), it may be necessary to rev engine or purge air from the cooling system.
Add distilled water until level equalizes (min/max mark) in degas bottle (this may take several days).
Use test strip to test and add SCA if applicable.
This method will yield approximately a 50/50 mixture of coolant/distilled water. It is always best to have the freeze/boil protection tested with a quality refractometer. Most shops will do this free.
Write down date and mileage of coolant maintenance for future use.
Stewart
Old Feb 4, 2009 | 09:25 AM
  #38
superduty4x4
Missed this one yesterday- yes I got it running, with a little prodding from Boyer.
So no ELC coolant for the early turd? Or, if the seals are the issue with the ELC in early trucks I wonder if since I'm replacing the pump already if it would be okay? Gonna have to dig around a bit on this.
Old Feb 4, 2009 | 10:38 AM
  #39
F250_'s Avatar
F250_
Chase:
Yes, I'm going with the ELC. On the theoretical issues, I suspect, in all honesty, that the thermodynamics of the engine (and it's associated performance) is improved by the slightly higher temperature, but the difference is probably too small to measure for those of us not in an experimental and completely controlled research environemnt - that's every one of us, I believe.
The thing is that thermodyanics are real, and work in real ways. Given that the OEM (Navistar) designed the engine to run with a 203* stat, I tend to accept the "improvement" concept and will run that way once I get the new one installed. Most of us are perpetually tinkering with one or more things that also effect engine performance and efficiency, which is probably one of the largest reasons why no one has ever documented a measurable improvement.
Again, diesel combustion efficiencies are known scientific realities, and the efficiencies of energy transfer change with combustion temperature, which is true for any and all fuels. If the new stat pushed me slightly closer to peak efficiency, I'm going to take it and run.
Old Feb 4, 2009 | 10:46 AM
  #40
superduty4x4
All good points Pete, but I still question the value (return on investment) for the Diesel Site 203 stat. I might call an IH dealer today to see if they offer a 203 stat and at what price just for grins.
Old Feb 4, 2009 | 11:00 AM
  #41
LoneRanger416's Avatar
LoneRanger416
Wow.
Thanks for all the info on the subject guys. Looks like this is right on time for me. Had to take my 02 PSD in for a health check wanting to make sure Im keeping up on things and was told that the water pump bearings at the fan/pump connect have a tad bit of play(he wiggled the fan a bit back/forth to show me). The mech told me this will cause the pump to eventually fail. Seems logical, would you guys agree?
Keeping in spirit with the FTE DIYers, while still learning to work on the ol girl myself, i believe your write ups have given me the confidence to go ahead and get er done myself($750 them or $150 or so me).
So using a Airtex pump from NorthernAuto, replace tstat(stock should be ok here in AZ since its usually 10k degrees here) and relpace fluid w/ Rotella ELC or Fleetrite ELC.
OK, possible stupid question: Should I flush w/ old pump on, new pump on or does it make a diffrence? Thxs again all!
Old Feb 4, 2009 | 11:14 AM
  #42
SGnAZ's Avatar
SGnAZ
Not a stupid question at all.I would like to know this as well.
Where are you in AZ?
Old Feb 4, 2009 | 11:24 AM
  #43
LoneRanger416
Where are you in AZ?[/quote]
Im here in East Mesa around Sossman/Guadalupe area. My wife was raised in ur neck of the woods. 3rg Generation QC
Old Feb 4, 2009 | 11:32 AM
  #44
superduty4x4
I would say flush with the old pump on, but it prolly doesn't matter. Good question tho!
Old Feb 4, 2009 | 12:33 PM
  #45
strokersace's Avatar
strokersace
Originally Posted by jdecker88
Agreed the Airtex Pump, diesel site 203 T-stat and housing along with a dual alt upper radator hose and a lower radiator hose will set you up. If you go with Rotella ELC you really won't need a coolant filter from what I have read around.
What's the difference on the lower radiator hose? I've already got the dual alt. upper hose, but didn't know there was a difference with the lower.
