How does a open rear work ?
Old Jan 28, 2009 | 05:52 PM
76highboyscode's Avatar
76highboyscode
Question How does a open rear work ?
I know how most rears work but how does a open rear work? Is it simular to limited slip? Ive got an open rear and was planing to open it up this weekend and weld it up. But I was just curious on how one worked thanks for any input-------Robert
Old Jan 28, 2009 | 06:11 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
A Lincoln Locker huh? You aren't driving this on the street are you?
Old Jan 28, 2009 | 06:16 PM
76highboyscode
Yeah,,,,not to far just around to area mud holes----Ive welded plenty of 9 in. rears and yea I know how the tires wear harder like this but this is no worrie,,since this truck is just a weekend toy.
Old Jan 28, 2009 | 06:37 PM
Poison Oil Racing's Avatar
Poison Oil Racing
If you have welded plenty of 9 in rears in the past then you should be familiar with an open rear, otherwise you wouldn't need to weld it.
Basically an open rear means power goes to the wheel that can spin. So if you are stuck in mud and only one wheel is spinning, that is the wheel that was open and available to spin.
Old Jan 28, 2009 | 08:49 PM
bartn98's Avatar
bartn98
tire wear isnt your main concern...its axle breakage and other drivetrain related stress...but i guess you know that if youve locked 9inchers before
Old Jan 29, 2009 | 11:04 AM
zak8tac's Avatar
zak8tac
Correct me if I'm wrong but an open diff works like this. Left axle speed + Right axle speed = drive shaft speed (taking into account gear ratios). Meaning if your going straight without spinning any wheels both tires will be spinning the same speed. If you turn one wheel spins x speed while the outside wheel spins that much faster than the other so that the combined speed still equals the initial speed. Meaning when your stuck and one wheel is spinning and the other isn't, the spinning wheel will be turning twice as fast as if both the wheels were spinning. Right?
Old Jan 29, 2009 | 06:54 PM
jimlj's Avatar
jimlj
HowStuffWorks "Open Differentials"
robert421960
Jul 1, 2011 08:52 PM
58AZF100
Nov 13, 2010 03:15 AM
Robert6401
15
Sep 30, 2005 09:57 PM
krazdndenver
User Gallery & Picture Display
Nov 9, 2002 01:37 PM
1ole4d
114
Feb 8, 2002 02:48 PM
