Issues still
Old Jan 28, 2009 | 11:16 AM
Flea's Avatar
Flea
Issues still
So i have replaced my idler pullley and the alternator.
Truck seems to charge fine and keep a charge.
The temps are next to zero here in KC.
I keep getting a popping noise in my big 6637 air filter. Anyone know why?
I still have power loss when accelerating from a stop. When cold the truck will die when I shift into reverse.
Truck seems to drive better when it is warm.
I think I know the problem. The tranny isn't getting cold enough.
I think that when I put in the Tru Cool monster tranny cooler I didn't put in the thermostat inline with it that it came with.
I will put that in and see if all is well.
Any other ideas?
Thanks
Fletch
Old Jan 28, 2009 | 11:46 AM
Action4478's Avatar
Action4478
popping from the intake may be a bent push rod ,or a cracked rocker arm...
Old Jan 28, 2009 | 11:58 AM
Flea's Avatar
Flea
It comes and goes. Wouldn't that be there all the time?
I just spoke to the dealer and they say that it could be a wastegate sticking! I didn't think these trucks had wastegates?
Old Jan 28, 2009 | 12:50 PM
Neal 97 250's Avatar
Neal 97 250
No we don't have waste gates. Typical dealership answer. Stay away from them if that is their answer.
Old Jan 28, 2009 | 01:27 PM
Action4478's Avatar
Action4478
Originally Posted by Flea
It comes and goes. Wouldn't that be there all the time ?
I don't recall you saying it was intermittant ,, if it were bent it would be there all the time ...
Old Jan 29, 2009 | 08:00 PM
Flea's Avatar
Flea
Okay, so I put the thermal bypass valve on in line with the Tru-Cool 4637.
I added a about a half quart of tranny fluid and it doesn't die anymore when I put it in reverse.
Any ideas what would have caused it to die in reverse? Does reverse take the most fluid?
MadVan are you out there?
Old Jan 29, 2009 | 09:14 PM
Flea's Avatar
Flea
Mic check mic check one two! Is this thing on?
Old Jan 29, 2009 | 10:29 PM
c00nhunterjoe's Avatar
c00nhunterjoe
has to do with line pressure, if i recall the tc needs (?) psi to stay disengaged, when you dont have that valve installed and select reverse it uses more fluid pressure then the pump can deleiver to engage reverse and you lose the pressure that is holding the tcc disengaged resulting in a stall
Old Jan 29, 2009 | 10:43 PM
Flea's Avatar
Flea
So now I get a CEL under hard acceleration.
Any ideas with all these symptoms.
Popping in the intake
lack of power?
racincowboy
Feb 17, 2009 03:12 PM
rocco913
Nov 5, 2008 03:29 PM
NMRider
32
Jun 6, 2006 11:04 PM
rockyrider
Apr 1, 2005 07:34 AM
2shus
Oct 24, 2003 04:17 PM
