Tranny Cooler Install
Old Mar 31, 2005 | 10:50 PM
rockyrider's Avatar
rockyrider
Question Tranny Cooler Install
UPS just dropped off my Tru Cool LPD 4590 transmission cooler, gonna put her in Saturday. Should I remove the factory installed piece of junk, or leave it and install the Tru Cool next to it and hook them up in series??
Old Mar 31, 2005 | 10:54 PM
superrangerman2002's Avatar
superrangerman2002
Hook them both up, you can never have too much cooling.
Old Mar 31, 2005 | 11:10 PM
HeatStroked's Avatar
HeatStroked
I deleted the stock cooler and went with the Tru-Cool alone. I was concerned about fluid flow through two coolers. Haven't heard anything negative about either type of install. I haven't seen anything over 140 degrees yet.
HERE is pix of stock one and the Tru-Cool.
Old Mar 31, 2005 | 11:15 PM
superrangerman2002
It really isnt a big deal running both, you will just have to make sure the fluid level is at the proper level in the tranny.
Old Apr 1, 2005 | 07:34 AM
mueckster's Avatar
mueckster
I have my TruCool mounted, behind the grille, in a series with the stock coolers. The top 2 ears on the cooler will line up with the 2 upright bars, if you have the late body style. I mounted the top 2 with bolts thru the bars and ziptied the bottom ones. No problems with this installation. May use J-bolts at the bottom if the zipties break. They are there just to keep the cooler from swinging on the top bolts. I got the installation kit (bolts, extra hose, and instructions) with the cooler from dieselsite.
SoCalAngler
Sep 8, 2014 11:26 PM
Mat J
Apr 25, 2010 05:12 PM
Joe28443
Feb 26, 2010 02:15 PM
Armalite
Jun 3, 2009 06:13 AM
PSD Bill
13
Oct 25, 2005 12:13 PM
