Strange Check Engine Light Problem
Old Jan 27, 2009 | 06:34 PM
WH90's Avatar
WH90
is there anything else that would make the truck run this bad there are no codes in the PCM except the P1316 - IDM Codes Detected but randomly works then quits what else could this be
Old Jan 27, 2009 | 08:26 PM
Pocket's Avatar
Pocket
If you are getting the P1316 code, it means that there are codes stored inside the IDM itself. Now if those codes are left over from the repair, then they need to be cleared out. But with the problems you are having, you may have several issues going on at once. First is the grey CPS, second, is what's causing the P1316.
Old Jan 28, 2009 | 09:02 AM
WH90's Avatar
WH90
true, this morning it did something different when its cold it runs like crap but when its warm it runs better, but you can feel and hear when the pcm controls the idm to do something maybe the coolant sensor is out or something
Old Jan 29, 2009 | 03:05 PM
WH90's Avatar
WH90
Update
ok i still been working on this so i replace the IDM today and it did not fix it what else do i need to do?
OldWoodsDiesel
37
Jan 13, 2020 11:53 PM
noober0x
Sep 13, 2016 07:17 PM
scottddove
Jul 31, 2015 02:02 PM
gregorymw
16
Aug 31, 2012 09:05 PM
93f1505.0L
32
Sep 3, 2011 05:59 PM
