going to ford
Old Jan 28, 2009 | 11:25 PM
conman3300's Avatar
conman3300
going to ford
well im going to ford next week for an overhaul on some things
here's the list so far
1.change oil
2.change trans oil
3.fix the motor on front driver side window
4.align tires
5.new steering stabilizer shock
7.check u-joints
8.change sway bar end links
9.new windshield
anything else i should have them check for while im at it
and also there's been a crunching sound ever since i got new tires in July when i turn left and go down a speed bump and when i go up driveways so hopefully the say bar will fix it so if you have any ideas on what it might be plz put them
thanks
Old Jan 28, 2009 | 11:27 PM
triskit16's Avatar
triskit16
They will find enough wrong with it...we dont need to add to it!
If you are mechanically inclined we could take you pretty much step by step on almost if not all that jazz...any particular reason youre going to the dealer? Warranty work? Special service deal when you bought it?
Old Jan 28, 2009 | 11:29 PM
conman3300's Avatar
conman3300
ha no all there going to do is a list im printing out and that's it.
so just put anything i would need to add to it because the stuff i listed is a must i think
thanks
Old Jan 28, 2009 | 11:31 PM
hucka1a's Avatar
hucka1a
You can use PB blaster or wd40 to help find the crunching sound. Most likely it will be your front sway bar bushings or your front leaf spring isolators. You can spray some oil on the isolators, than push down on your bumper and listen for the sound. If it's sill there, spray some on your sway bar bushings to see if that quites it down. Once you figure out which one it is, you'll know what needs to be replaced.
Old Jan 28, 2009 | 11:34 PM
triskit16's Avatar
triskit16
Definitely do the window motor yourself. Did that 3 days ago. Remove door panel, take speaker out, upplug old motor, 3 bolts, and reverse procedure! Make sure you lube the tracks up before you give up on the motor....
conman3300's Avatar
conman3300
ok i will to that tomorrow thanks but i think it wouldn't hurt replacing them anyway and im doing most of the main stuff now because im going to be giving this truck to my lil bro this summer as his first truck and want to make sure it will run as great as it has for me
thanks
Old Jan 28, 2009 | 11:35 PM
conman3300's Avatar
conman3300
where do i buy the motor?
Old Jan 28, 2009 | 11:39 PM
jkidd_39's Avatar
jkidd_39
http://www.ftepartsguy.com/
or try ebay
Old Jan 28, 2009 | 11:42 PM
triskit16's Avatar
triskit16
I got mine from Advance Auto actually...
Ill do a search for ya...
Old Jan 28, 2009 | 11:44 PM
puller45's Avatar
puller45
1.change oil
2.change trans oil
4.align tires
7.check u-joints
9.new windshield
thanks
I'm think'in your new tires might be rubbing on your mud flaps if you have them. Does it happen when you turn sharp and go over something uneven? Ypu may need to raise the front end a little with longer shackles.
Old Jan 28, 2009 | 11:46 PM
triskit16's Avatar
triskit16
FTEPartsguy has them at 77 plus a 30 dollar core charge...plus shippin...
Advance has them for 49.99 plus 25 core charge
http://shop.advanceautoparts.com/pro...e=1326&PTSet=A
Old Jan 28, 2009 | 11:47 PM
conman3300's Avatar
conman3300
yes it happens when i go over something uneven.
Old Jan 28, 2009 | 11:51 PM
puller45's Avatar
puller45
sounds like the same problem I have. I got a set of shackles on EBAY for $55.00 and shipping, I'm hoping it will fix the problem.
Old Jan 28, 2009 | 11:52 PM
conman3300's Avatar
conman3300
i have a 6inch lift though. so does that still mean i need shackles?
Old Jan 28, 2009 | 11:56 PM
puller45's Avatar
puller45
Remind me to read the sig before I post. Never mind, probably a different problem.
