Old Jan 26, 2009 | 05:50 PM
bigenough's Avatar
bigenough
Motor is out and oil pan leak confirmed, sealed and now just looking over everything and cleaning all sensors and turbo, also goin to 4 1/2" straight pipe inot stacks, I have found 2 exhaust leaks 1 on the manifold and 1 on the up-pipe, would that cuase the engine light to come on?
Old Jan 26, 2009 | 05:59 PM
superduty4x4's Avatar
superduty4x4
Leaky exhaust causing an SES? Not that I've ever heard.
Old Jan 26, 2009 | 06:01 PM
fxstbchopper's Avatar
fxstbchopper
No the engine light should not be tripped by an exhaust leak. Have you had the codes read to see what they are.
beer boy's Avatar
beer boy
need more info, what are you doing?
can you get a code reader to tell you what code(s) are there?
Old Jan 26, 2009 | 06:06 PM
bigenough's Avatar
bigenough
well right now the engine is out, where can I buy a code reader or do I have to take it to some one?
Old Jan 26, 2009 | 06:25 PM
beer boy's Avatar
beer boy
you have the engine out of the truck?
why?
Old Jan 26, 2009 | 06:31 PM
Izzy351's Avatar
Izzy351
To fix the pan leak.
Old Jan 26, 2009 | 06:35 PM
bigenough's Avatar
bigenough
Yes, the pan leak, could not get it to seal, Pulled the motor to remove the pan and see what I was working with pan was jacked up, after a little abuse it eas ready for install and it did seal this time
Old Jan 26, 2009 | 06:39 PM
beer boy's Avatar
beer boy
umm, ok. good that you got it. so is the engine back in now? is it running?
Old Jan 26, 2009 | 06:41 PM
bigenough's Avatar
bigenough
No working on the exhaust leaks and sensors and then putting it back in.
Old Jan 26, 2009 | 06:42 PM
Izzy351's Avatar
Izzy351
Man, I miss having a nice full auto shop on base....
Old Jan 26, 2009 | 06:48 PM
beer boy's Avatar
beer boy
something kinda doesnt sound right. you have the ability and ambition to take the engine out, and be able to run it out of the truck, but you dont have a code reader or know where to buy one.
what gives?
Old Jan 26, 2009 | 06:54 PM
Izzy351's Avatar
Izzy351
He's on Dyess AFB, TX. FULL auto-shop with pretty much any tool, and guys that work there that usually know everything. Well, any tool but Ford diesel code readers, obviously. When I was on Tyndall back in '07, I LOVED going to the auto shop. I also frequented the one on base when I was overseas.
Old Jan 26, 2009 | 06:58 PM
beer boy's Avatar
beer boy
that sounds freakin awesome. research a code reader or maybe someone will pipe in. then your set. its probably just a unhooked sensor or something. let us know how it goes. without a code your just left to recheck all the sensors etc.
id put it back in and see what it doe s then.
Old Jan 26, 2009 | 07:24 PM
bigenough's Avatar
bigenough
For one yes there is a shop on base but my truck will not fit in the shop and they charge to much for my little E-4 pay, so im doing it all at home, and no i dont have a way of running it out of the truck. Its my baby thats where the ambition comes from!!!!
