Replacing power lock actuators??
Old Jan 26, 2009 | 08:20 AM
Supercab's Avatar
Supercab
Wink Replacing power lock actuators??
How do I go about replacing the power lock actuators on my 1994 F150?
Old Jan 26, 2009 | 09:29 AM
BigBlueOx's Avatar
BigBlueOx
well I'll tell you, it takes a lot of patience.
Take the door panel off
drill out the 7mm rivet that holds the actuator in place from the outside of door
(its real low under the door latch)
Proceed to fish the actuator off of rod from inside door
the hardest part is trying to find a rivet big enough to put the actuator back on with.
Old Jan 26, 2009 | 01:38 PM
bullredguy's Avatar
bullredguy
as for the rivets ford has long used the 1/4 diam alum peel rivet for these applications the rivet you need also needs a specialized rivet gun to set them in place if you lack the gun just go buy some 1/4x20x1/2 hex head bolts and they will work just fine as there is plenty of room down in the door to reach the bold head
Old Jan 26, 2009 | 01:44 PM
BigBlueOx's Avatar
BigBlueOx
I've tried 1/4 and they were a little loose so I ended up getting some 7mm. And yes 1/4 bolt would work just fine.
Old Jan 26, 2009 | 04:46 PM
Jeff Dodson's Avatar
Jeff Dodson
I just replaced mine, I used the old mounting bracket because it still had the plastic on it. I used a carrage (sp) head bolt. filed it out so the square would fit tightly in the hole and then carefully installed it. Whe I tightened the nut down, I cut off the end. There is plenty of room in the door jam for the nut as long as you cut off the end
Old Jan 28, 2009 | 05:20 AM
Supercab's Avatar
Supercab
Wink
Thanks guys!!!---I've been out of touch for a few days....
Smokeythebear
1997 - 2003 F150
51
Apr 13, 2021 06:00 AM
bluef72
Oct 17, 2013 11:26 PM
cocot
Sep 15, 2012 06:35 PM
dmdillon
Jul 18, 2006 08:22 PM
JOHNJAY28
Dec 12, 2002 08:39 PM
