I dont remember how many lights are in it but let me know how the led's work out. I had thought about it but wasnt sure how well they would light the dash up.
I will let you know how it works out. My nephew put white ones in his car and they looked good. Nice and bright. I was wanting to go with red. We will see.Scott
I have a 96 cluster in front of me. There are 17 bulbs. 5 of these are for illumination. 11 are for various functions: Check Engine, ABS, Brake, Belts, Hi Beam, Amp(Battery), Right Turn, 4x4, Low, Air Bag, Anti-Theft, Left Turn. Your truck may not use all these functions; so it may be waste to change some of those bulbs. Some are only during startup and may also be trivial.
Don't use red LED's. The dash panel is impregnated with color dye that gives the white light color as it passes through, so not only will the lights be dim, it will be an ugly color if any light gets through. Get white LED's.
I was thinking the same thing but wasnt sure...cant switch the color. I would think green LEDs would be the brightest though.
