tail light issues
Old Jan 25, 2009 | 06:55 AM
86BroncoGuy's Avatar
86BroncoGuy
tail light issues
i have a 79' F-150 custom, and my tail lights, and rear turnsignals quit working but my brake lights and hazards work fine as do my head lights and front turn signals.... does anyone know whats wrong? any help would be great thanks so much
Old Jan 25, 2009 | 07:50 AM
73FOMO's Avatar
73FOMO
Turnsignal and rear lights on same circuit I believe. Hazards and brake lights are on a different circuit. Check your wiring at the back to see if you are getting power. Green wire should be RH rear lamp and Marker, Yellow/Black should be LH Rear lamp and Marker. Green/Wht is LH Turn Signal and Dash Indicator, and Wht/Black RH Turn Signal and Dash Indicator. Check you grounds at the rear lights. You have to have a bad ground if the front signals are working. Let us know if you have 12v on the green wire and yellow/black wire in the back with lights on, and also the green/wht, and wht/blk with the turn signals activated.
Old Jan 25, 2009 | 08:20 AM
86BroncoGuy
um i dont have a volt meter... and do u happen to know where the grounds are back there?? i looked but didnt see them... could it be a bad fuse?
Old Jan 25, 2009 | 09:45 AM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Check the connector in the frame by the gas tank, it likes to corrode.
Also check for corrosion in the light sockets.
Josh
Old Jan 25, 2009 | 10:55 AM
sedly's Avatar
sedly
The ground should be behind the tail light caseings.You will have to pop the tail lights out to see the ground.
Old Jan 25, 2009 | 01:20 PM
73FOMO's Avatar
73FOMO
A cheap $3 voltage circuit tester will do if you don't have voltmeter. It wouldn't be a fuse if fronts work. You are losing power and or ground somwhere between the turn signal switch in the column and the rear lights, and the wires go straight from the column to the back albeit through a couple of plugs (as bullit390 said good to check those). Start at the taillight and work back to the color of wires coming out of the column to narrow down loss of current...using the colors I suggested above. You need at least a circuit tester (you know the one that lights up if there is voltage) to help diagnose electrical problems.
Old Jan 25, 2009 | 07:31 PM
86BroncoGuy
there dosnt appear to be a connector by my gas tank, also i didnt see any conectors from the lights to the cab.... i had a hitch instaled on the truck at u-haul over the summer could that do it??
Old Jan 25, 2009 | 07:43 PM
86BroncoGuy
and i noticed they didnt tape the connections, they just used the quick connects like the wire tap things...
Old Jan 25, 2009 | 08:08 PM
86BroncoGuy
also my dash lights have been flickering for quite some time and finaly just quit working... dont know if there related or not but i figured id mention it
Old Jan 26, 2009 | 08:18 AM
Bullitt390's Avatar
Bullitt390
Well, the connector at the back of the truck is there to disconnect the frame harness from the bed harness. That way you can just lift the bed off and not have to worry about taking out all the lights.
If indeed U-Haul monkeyed with the wiring that would definatley look there first.
The dash lights are not directly related, although the light switch is many times the culprit, try turning the **** back and forth and see if it makes the dash lights do anything.
Be patient, these problems will get handled.
Josh
Old Jan 26, 2009 | 02:58 PM
73FOMO's Avatar
73FOMO
Follow that rear harness up to the cab. My connector for the rear harness is on the engine side of the firewall in the engine compartment...but, I would definitely check all of the wiring u-haul did and would chunk those twist connectors and at least get crimp on connectors or better yet solder and shrink wrap the connections. I bet that is where the problems exist for the rear. The power for the interior lights comes from the blue/red stripe wire from the headlight switch, it then routes inline through the fuse panel...should be a 3amp fuse in the panel and also routes through to the dome lights and door jamb switches. Problems there could be the fuse, the headlight switch, or bad ground at the door jamb switches...they tend to get a bid corroded. Like I said go to your local parts store and pick up a $3 circuit tester and start at the Uhaul wiring, and as mentioned be patient. You can find and fix the problem.
Old Jan 26, 2009 | 03:13 PM
86BroncoGuy
twisting the switch used to work or the dash lights but not anymore... ill go check the firewall for the disconect as soon as i can... thanks for the help ill get back to u when i find more out
Old Jan 26, 2009 | 08:36 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
If U-haul messed it up, then I would take it back to U-haul to correct it or at least get your money back.
Especially if it hasn't been too long ago, and your state law disallows incidential and concequential damage disclaimers.
Some of the people at U-haul do not impress me.
Old Jan 26, 2009 | 08:41 PM
81-F-150-Explorer
Sounds like you need a light switch, along with the wiring problems you have.
Old Jan 26, 2009 | 10:11 PM
86BroncoGuy
well its not the u-haul wiring cause i have no power back there, not even before the u-haul wiring... the grounds all apear good and are not corroded, also the rear light connector(or disconect, located on my firewall apears to be good with no corrosion. could the light switch cause just the lights in the rear to quit working??
