before the turbo has a quicker reading. they're is a nice flat spot on the drivers manifold next to the oil filter with pleanty of room to drill and tap the manifold . use grease on the drill and tap to catch the metal shavings. i just put one in last week and from the advise i researched here the installation went smoothly.
According to Autometer, It should be installed 1-2 inches from the turbo outlet in the down pipe. Got the instructions here in front of me.
This sounds crazy but autometer doesn't know what is best for your engine. We watch EGT's for the sake of the pistons not the turbo. I was the probe close to the pistons not the turbo.
i was thinking the manifold t tow but couldnt the other side be hotter just wondering this my uptubs are off i could mount there but the manifold would be easy first i gotta get me trans but i was wondering so i can get all that reedie
by other side do you mean after the turbo? If thats what your asking then no. After the turbo is a slower reaction time and will be 300 -500 degrees cooler under any given condition and its just not known exactly when you should figure 300 degrees or 500 degrees.
nope sorry i mint left side of engine and right side seem like it be better somewhere in the med for both side of engine but i dont no where that be just a thought but most just put in the left manifold then it must work then ill do that its easyer anyways thinks for the help
