Pyrometer sending prope
Old Jan 25, 2009 | 11:38 AM
hueyman's Avatar
hueyman
All the exhaust ports should be the same temp there should not be any one hole that is hotter or cooler than the others at least not by much. In my experince a bad injector will make that cylinder hotter by hundreds of degrees.
Old Jan 25, 2009 | 12:59 PM
bmxstreet15's Avatar
bmxstreet15
Wow, big difference! I stand corrected. And on that note, where would be the best place to install the thermocouple, which side?
Old Jan 25, 2009 | 01:16 PM
live2wheel's Avatar
live2wheel
Originally Posted by live2wheel
before the turbo has a quicker reading. they're is a nice flat spot on the drivers manifold next to the oil filter with pleanty of room to drill and tap the manifold . use grease on the drill and tap to catch the metal shavings. i just put one in last week and from the advise i researched here the installation went smoothly.
drivers side manifold
Old Jan 25, 2009 | 02:11 PM
bmxstreet15
What size drill and tap? 1/4 NPT?
Old Jan 25, 2009 | 02:39 PM
live2wheel's Avatar
live2wheel
1/4-18 npt tap and 7/16 drill.
Old Jan 25, 2009 | 02:57 PM
BlueMule's Avatar
BlueMule
That all depends on what size thermocoupler you get. Mine are 1/4 NPT but you can also get 1/8 NPT
Old Jan 25, 2009 | 04:22 PM
live2wheel's Avatar
live2wheel
good catch bluemule. autometer does offer 1/8 npt.
reps to ya.
Old Jan 25, 2009 | 06:09 PM
RubberDuck's Avatar
RubberDuck
Could you guys see the pics in that thread? For some reason I can't see them here at work. Hmmmm.
Old Jan 25, 2009 | 06:16 PM
BlueMule's Avatar
BlueMule
Nope, no pictures Cody.
Just an empty box that says "Attached Images"
Old Jan 25, 2009 | 09:10 PM
RubberDuck's Avatar
RubberDuck
Well that's no good. Wonder what happened. I'll holler at Scott and see what's up.
