Sponsored by: Auxito
speedometer stops at 30 mph
Old Jan 24, 2009 | 04:07 PM
mkorbe's Avatar
mkorbe
I own a 1997 f-150, 4.2 litre, 4 wheel drive. The speedometer quits working at 38 mph and sometimes does not return to 0 even after the engine is off. I have replaced the speed sensor but it did not cure the problem. Could it be a bad ground? I have found a couple of instrument clusters at salvage yards, but they have been out of trucks with v-8's. My truck is a base model with no tachometer. Are the clusters interchangeable?? The other guages in the cluster work fine, it's just the speedometer.
Old Jan 24, 2009 | 04:26 PM
LxMan1's Avatar
LxMan1
https://www.ford-trucks.com/forums/8...at-40-mph.html
Old Jan 25, 2009 | 10:50 AM
Kijutsu's Avatar
Kijutsu
I haven't found any answers myself to a very similar problem. I'll keep looking and let you know what I found out, in the meantime, I emailed Bob's Speedometer, a local shop here and asked a few questions and I've not gotten anything back yet, but it was a Saturday I emailed them. As far as I know, you CAN interchange the clusters, but I don't know for sure, I couldn't find any info.
Old Jan 26, 2009 | 08:14 AM
mkorbe's Avatar
mkorbe
I did get some info from a senior ford mechanic and he did tell me that the clusters are interchangeable. I found a cluster at a salvage yard and will pick it up in the next day or two. The mechanic told me that the motor in the speedo is not functioning properly since i have already replaced the speed sensor and all of the other guages work. I've got my fingers crossed that this will work. I am surprised that he told me the tachometer will be functional with the v-6 engine even though it came out of a v-8. I'll let you know how it turns out.
Paul Bostic
2004 - 2008 F150
Feb 7, 2017 07:54 PM
linjer
Jan 9, 2017 08:47 PM
mikedepalma
Feb 18, 2016 10:54 AM
boarhawg
1997 - 2003 F150
Apr 7, 2011 10:34 AM
redboz
Electrical Systems/Wiring
Apr 25, 2006 10:30 PM
