Help with Y Block Dist Identification
Old Jan 23, 2009 | 01:35 PM
TxF100's Avatar
TxF100
I am getting ready to install a Petronix Ignitor and was thinking... The 272 Y Block engine in my 55 F100 was rebuilt and the previous owner could have installed a 57+ or the 54-56 Distributor and I do not know which one it is. Any Idea?
Old Jan 23, 2009 | 03:51 PM
fking1's Avatar
fking1
Are you aware that 272 Y-Blocks were not available on 55 F100's?
Std. was 239. A 256 was available on F600 and 279 on F750.
All 55 engines were either yellow or red.
Old Jan 23, 2009 | 04:44 PM
TxF100's Avatar
TxF100
I believe you may be correct. My VIN Plate states that the engine is a Code V which according to the VIN info at clubfte, is in fact a 239. I did look at the Block and found the Code ECG which I believe would be a 272. I pulled the valve covers last weekend and found the engine looks very very clean, so I surmise the engine must be rebuilt.
Now if I could just figure what Distributor I have I would be set
Old Jan 23, 2009 | 07:52 PM
Old F1's Avatar
Old F1
Is there a part number or casting number on the distributor?
And it looks like it has been worked on by the new type rubber booted lead wire.
Old Jan 23, 2009 | 09:01 PM
2many56s's Avatar
2many56s
the early "load-o-matic" distributors had two springs visible as soon as you removed the cap. I don't see the springs, I'm going to go ahead and say 57+
Old Jan 23, 2009 | 09:14 PM
TxF100's Avatar
TxF100
I could not see any casting number, but its hard to tell as its installed. It does say motorcraft inside of the Dizzy.
Old Jan 24, 2009 | 07:37 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
No casting or part numbers on dizzies, only Ford ID numbers.
Motorcraft = replacement Y block dizzy. Motorcraft did not exist before 1972.
Look on the curved part of the base for a STAMPED ID number, something like this: C3TF-12127-AA.
My guess is, you have a 1957/64 272/292 distributor.
Old Jan 24, 2009 | 10:03 AM
TxF100's Avatar
TxF100
Does anyone have a picture of the inside of a 54-65 Dizzy to compare the two?
Old Jan 24, 2009 | 10:06 AM
TxF100's Avatar
TxF100
The paint under the Blue on the intake and some of the accessories like the fan bracket are infact Red.
Old Jan 24, 2009 | 02:59 PM
TxF100's Avatar
TxF100
Got an answer... Found a site that has a picture of the 54-56 Distributor. There are infact two springs that can be seen if you remove the cap. here is a picture from PerTronix Ford Applications Thanks all for the great advice!!!
Old Jan 24, 2009 | 03:33 PM
NumberDummy
There are two springs on the 1957/64 292 dizzies also.
If you get the ID number off your present dizzy, I can ID it.
Scottbmcd
Aug 12, 2014 10:35 PM
60FordF100
Nov 19, 2007 09:25 PM
Fifty4F100
54
Apr 30, 2003 08:29 PM
JefF100
Apr 25, 2000 12:34 PM
