Electric Speedometer
Old Jan 23, 2009 | 12:01 PM
motorhead66's Avatar
motorhead66
Heres a good question for everyone. I am looking at installing a custom gauge set in my 78' F150 specifically Autometer. Has enyone installed for helped with installing an electric speedometer? I researched at the Autometer website and it requires the Hall effect? sensor in place of the cable but Autometer also says that you can't use one with a solid core ignition system. Is it possible to install this gauge in my truck and what the heck is a solid core ignition system.
Old Jan 23, 2009 | 02:50 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Solid core are the old, original racing spark plug wires. Pretty much everything sold nowadays has some sort of RF suppression in the jacketing.
Josh
Old Jan 24, 2009 | 06:48 AM
teds74ford's Avatar
teds74ford
A couple of years ago, an old member called IvanRibic put one in, and if I remember correctly, he used the drive gear out of a late 80s van. Not 100% sure of that, but you might search his name and see what you find.
Old Jan 24, 2009 | 07:54 AM
Don Senkow's Avatar
Don Senkow
Take another look at the Autometer website. They have sensors listed under the accessorie section. 5291 or 5292 are 2 numbers I found. They work with Sport Comp Gages. Says the Gages also work with factory electronics. Both those senders allow you to retain the cruise control function......Don
ShamelessMT
Jun 25, 2009 02:55 PM
HzrInAz
Oct 3, 2005 11:20 PM
FERacing66
Mar 31, 2004 11:40 PM
LEckart
Feb 20, 2004 07:40 AM
