rear window weatherstrip question
There are three types of Rear Window seals used between 1973-1979.
The following part numbers may have been updated.....
1: 1973-1979 : D3TZ-1042084-A : Without Inserts. (Used with Fixed or Sliding Glass)
2: 1973-1976 : D3TZ-1042084-C : With Wide Aluminum Insert (Fixed Glass only)
3: 1977-1979 : D7TZ-1042084-A : With Flexible "Chrome" Plastic Insert. (Fixed Glass only)
You should use as new seal, but the one from a slider should fit the fixed glass. (IE: it's #1 from the list.)
The following part numbers may have been updated. Nope.
At one time there was D3TZ-1042084-B. Ford later replaced it with D3TZ-1042084-C.
The back glass plastic "chrome" window trim is still available from Ford as it was used thru 1996.
What's the same and what's different from 79-96? Does OEM windows and seals interchange in all those years?
The original weatherstripping looks to be in great shape so I figure it's worth a try. Just going to wait for a warm day this spring (or bum a friends heated garage!)peganit2, from what I've read on this site, '73 - 96 rear glass interchanges.
Thanks. I need weatherstripping too. I'm getting OEM.
Compare these weatherstrip part numbers against what's posted above.
1980/96: E1TZ1042084A .. Back Glass Weatherstrip w/o Mouldings.
1980/96: E3TZ1042084D .. Back Glass Weatherstrip with Mouldings.
1980/96: E7TZ1542084A .. Back Glass Weatherstrip-with Sliding Window.
The back glass is the same thru 1996.
And...1967/79 windshields are the same but the weatherstrips aren't.
1967/72 is different than what was used 1973/79.
It has to do with the corners.
All the seals and back windows will interchange, 1973-1996, because the window hole in the cabs are exactly the same. however....
The Rear fixed glass is slightly thicker for 1973-1979, than it is for 1980-1996. This is why a new set of seals were for the 1980-1996 trucks.
The Factory Sliders 1973-1981, were changed in 1982 so trucks with factory sliders after 1982 has a different seal yet.
It can be all mix and matched, but you if you put a 1973-1979 fixed window into a 1989 for example, you need a 1973-79 seal, or vise versa, a 1980-1996 window, in a 1973 will need a 1980-96 seal, for it to seal properly.
This is how I understand it.
Here is some more part numbers from the info I have. I believe most of these were updated to the ones that Bill Posted above. My Ford literature is grosely out of date, given to me by my local dealer, why I don't use it often for part numbers.
1: 1980-1982: E0TZ-1042084-B : Plastic Chrome Insert (Fixed Glass)
2: 1980-1982: E0TZ-1042084-A : Without Plastic Chrome Inserts (Fixed Glass)
3: 1980-1981: D3TZ-1042084-A : Without Plastic Chrome Inserts (Sliding rear window)
4: 1982-??? : E2TZ-1042084-A : with Plastic Chrome Insert (Sliding rear window.
According to my Ford O-S-I Catalog (on microfiche dated 1991), the 1973/79 back window glass was replaced by the 1980 and later back window glass.
After all these years, who really knows what's back there.
O-S-I = Obsolete-Supercede-Interchange
Do you have a microfiche reader? If so...I have TONS of extra slides. Ask....and ye shall receive.
I don't need OSI after 1991, because the Ford Dealer Parts Locator System updates part numbers for these later vehicles, and updates the older stuff if it's been updated..
Ford updates 10's of 1000's of part numbers every year...and...it's a ROYAL PITA to keep up with all this scheiss!
The 1980/89 Ford Light Truck Parts Catalog is available on a CD from hipoparts.com and was scanned from the last printed/microfiche versions, so most of the part numbers will kinda be up to date.
The 1973/79 version is also available, but was scanned from the first complete parts catalog and has errors and omissions.
This is the one that D used, and every day, there was a post with out of date part numbers that someone (not saying who), had to correct.
It's better than nothing, but that's all I have to say about it.
All my stuff after 1972 is on fiche, and is the newest available.
Check with local dealers, no one uses microfiche any longer, so if the reader is still there, you can prolly get it, and the fiche, too...for next to nothing.
You want the Mark VII version, introduced in the mid 1980's. The earlier readers are crap.
Ask about printed parts catalogs, too. Most dealers have thrown them in the trash, but you might get lucky.
I just did...60 paper parts catalogs from 1928 thru 2002, 500 microfiche slides and the reader: FREE!
I also got all the HiPo parts catalogs 1961/68, and a bunch of other stuff.
