Backspacing/Offset Question
Jan 20, 2009 | 09:03 PM
What backspacing/offset would be needed to run a 16X8 rim with 305s that will not rub the leafspring at full lock?
DCSpecial, I know your out there, you probably know what I'm planning.
Jan 20, 2009 | 09:40 PM
I'll bump you for so DC will see this.
Jan 20, 2009 | 09:44 PM
Im not 100% and DC will confirm but I don't think you could rub the leaf pack with 305's on 16x8's. I'm running 17x9 and 315's and have no problem, but did kiss the leaf pack when I had my 35x12.5-17's on. Just my .02 till DC comes by...
Jan 20, 2009 | 09:50 PM
For clarification...you're talking about removing the DRW spacer and using a SRW wheel?
If so, 4.5" of back space would be what you want on a 99-04 truck.
Jan 20, 2009 | 09:54 PM
Quote:
Originally Posted by
DCSpecial
Yeah, I want to put 8 inch rims in the front. What offset will I need? 0 or +2mm?
Jan 20, 2009 | 10:22 PM
On a 8" wide wheel 4.5" of Back Space is 0mm
+2mm would be ~4.58" of Back Space.
2mm isn't really going to make a difference (25.4mm per 1")
Jan 20, 2009 | 11:16 PM
RAMPAGE_F350
Why?
That truck looks great. Bring it up to the TS event.
Jan 20, 2009 | 11:28 PM
I completly agree mike
Tenn01PSD350
Why?
Jan 20, 2009 | 11:58 PM
Better tire wear, better handling maybe?
A 305 on a 6" wide wheel isn't the best combo for the above.
Jan 21, 2009 | 12:01 AM
DCSpecial
I don''t think he has 305s right now. I don't think he needs them either.
Jan 21, 2009 | 12:26 AM
Some of his previous posts mention running a 2" spacer between his rear duals due to the 305s.
Unless he has a smaller tire up front.
XXX4play
2009 - 2014 F150
Feb 25, 2014 06:42 AM
Brom014
Oct 29, 2012 09:02 AM
AndeyHall
Oct 3, 2010 08:06 PM
rptr00
Aug 14, 2010 10:40 AM
TDAVIS79
6.4L Power Stroke Diesel
Aug 5, 2010 11:16 AM
