stupid question but I need to know what the backspace/offset for stock wheels on a 2008 ford f350 4x4 srw is??? I am looking at buying new wheels and need to have something to compare the numbers to, looked everwhere and can find the stupid answer.... thanks again everyone
Conflicting data on Stock OEM Backspacing and Offset
Originally Posted by Quad Racer
The stock offset is 0
The stock backspacing is 4.5"
So if the new wheels are wider and the offset is 0 the backspacing will change. If the backspacing stays at 4.5" the offset will be a negative offset.
Quad Racer, there is a lot of conflicting information about the Ford Wheel specs. Can you please quote the source of your 0mm offset and 4.5" backspacing for the stock OEM wheels? This conflicts directly with the official Ford spec sheet, which says the stock OEM 17x8, 18x8 and 20x8 wheels all have "Inset" of 40mm, where "Inset" means positive "Offset". Here are the specs for 2010 which are the same for 2011:
