so the ebpv. will cause it to sound like it sucking air and by unpluging it it should take care of it? will it also help the flutering sound when the waste gate opens instead of a swoosh
Yes unplugging the EBPV will stop the sucking sound. But bnot sure what Fluttering sound you are talking about. The 94.5-97 PSD don't have a wastegate. Could you explain more?
heyyyy Tim was back for a second!!!!
ok back to the issue, explain more as Tim said, b/c these trucks have no wastegate. the '99-03 trucks had wastegates. also the '99-'03 turbos are bad about surging or "fluttering" at mid to high boost pressures(15-25 or 30psi.) the wicked wheel fixed this on those trucks, but if you have an OBS you already have a wicked wheel so if your turbo is fluttering then you may be in for a turbo rebuild
i have a 99 i replaced the waste gate. the fluttering is when you step on it and i guess its dumping the excess and that happens at high boost when i punch it. wicked wheel... does that replace the wheel inside the turbo. and what is obs
Reason: add more info
OBS- Old Body Style. Different from your truck. Wicked wheel is a new compressor wheel inside the turbo. The better fix for turbo surge is a ATS intake housing but its a little more $$.
the wicked wheel is basically a compressor wheel for a 94-97 turbo. as tim said the ats intake housing will help a little more, but is more money. the wicked wheel will help and isn't very much $$$.
