97 f-250 7.3 when driving after a cold start it sounds like i have a exhust brake when i let off the fuel pedal (no engine load) you can hear a sucking sound when hitting the pedal again. i was thinking maby my wastgate is sticking open a small amount but once the truck heats up it runs fine any help would be great thanks..
<!-- / message -->
Its the exhuast Back Presure Valve. the conector it on teh drivverside of the truck just under teh turbo. I belive it 2 wires. Ill see if I can find a pic.
Here is a pic of the connector compliments of Neal 97 250:
There is really no difference in umpluging it othere than it does not work anymore but when it di it hardly did anything anyhow. sometimes they get stuck closed and cuase problems so unpluging it prevents that. I think you are talking about disconecting the valve completly and im not sure on that one but im pretty sure unplugging the conector will do the same thing but easier.
Glad it worked for you also. Stick around here there is a vast amount of knowledge here.
Welcome to FTE, BTW
I will stick around. I have been reading alot on this site and have found alot of good info from all you guys. More then i could find in a service book. Thanks again for the help..
so the ebpv. will cause it to sound like it sucking air and by unpluging it it should take care of it? will it also help the flutering sound when the waste gate opens instead of a swoosh
