b1600,1602 codes
Old Jan 19, 2009 | 07:25 PM
Mover Man's Avatar
Mover Man
b1600,1602 codes
I just pulled the b1600, 1602 codes and am looking for info on what they are? And how to fix. My excursion is not starting and I turn the key off and retry and it will start. Are the codes related?
Thanks in advanced from a newbie.
Old Jan 20, 2009 | 12:29 AM
IDPisan's Avatar
IDPisan
Hey Brad, found this in some reading. Maybe someone else can chime in with their experiences.
B1600: No PATS key read by the PATS control. This can be caused by the PATS key, PATS transceiver, circuits between the PATS transceiver/PATS control, and/or the PATS control. For 1996-1997 Taurus Sable, 1996-1997 Mustang, and 1997-1998 Expedition/Navigator, overlay all wires from transceiver pigtail harness to control module if an intermittent failure cannot be corrected by replacing transceiver module.
  • B1601: Unprogrammed PATS key. There is no issue with the PATS key itself, but must be programmed into the PATS memory (unless maximum number of keys already programmed). Follow Spare Key Programming Procedure from the chart. No parts should need to be replaced for this code.
  • B1602: Partial PATS key was read. Verify that approved PATS key (Ford Rotunda, ILCO, Strattec, HUF, or Valeo) is being used. Large metal objects, additional PATS keys, or devices to purchase gasoline located on the customer's key chain can cause interference. Instruct the customer to keep such items from touching the ignition key during engine start. It is not necessary to remove the objects from the customer's key chain. Remote starter equipment can also cause this fault code. Remove any remote starter equipment close to the transceiver before conducting further diagnosis. This DTC can be caused by the PATS key or PATS transceiver.
Old Jan 20, 2009 | 12:32 AM
IDPisan's Avatar
IDPisan
Hmmmm, check out this link.
Ford Anti-Theft Systems Misunderstood
Old Jan 20, 2009 | 01:50 AM
Move over I'm coming's Avatar
Good article rep points given.
keninwa
2009 - 2014 F150
Jun 30, 2016 12:32 PM
olyellow
1983 - 2012 Ranger & B-Series
Aug 26, 2015 07:50 PM
dirkdriller
2004 - 2008 F150
Jan 20, 2014 06:05 PM
max harris
Oct 5, 2009 09:02 PM
chaser1602
1997 - 2003 F150
Mar 11, 2008 10:30 AM
