coolant temps ??
Old Jan 19, 2009 | 10:46 PM
oldbird1965's Avatar
oldbird1965
Originally Posted by FARM69
The OEM gauge is junk. There is no actual temperature reading that it displays besides whatever range "Normal" is.
The lower hose is going to be pretty cold especially during the winter months. These engines have amazing cooling systems that can handle just about anything. If your worried about it, you might try pulling your stat and making sure its closing all the way.
It also might be a great opportunity to put the 203 in.
I've been hearing this for years about the stock gauge. I have to say, I've said it many times, that my stock gauge does exactly what my installed gauge does. They both go up at the same time and they both go down at the same time. I have two temp gauges that act in unison. There, I just had to say that in defense of the stock temp gauge. On the other hand, the oil pressure gauge, as we all know, is a piece of garbage. Activited by six pounds of oil pressure, jump up to a certain spot and stays there telling you take you have at least six pounds of oil pressure. Junk!!!!
Old Jan 19, 2009 | 11:07 PM
BlueMule's Avatar
BlueMule
And I thought I was the only one thought the only thing wrong with the stock gauge was the lack of numbers. I too have both the stock and aftermarket and once I learned what letters correspond with the numbers I really dont need the 2nd one.
Old Jan 20, 2009 | 09:49 AM
oldbird1965
Well, I'll be darn, I thought I was the only one who had a Ford pickup where Ford screwed up and installed a 'real' gauge!!
Old Jan 20, 2009 | 09:53 AM
tjbeggs's Avatar
tjbeggs
yes it moves correctly but telling someone that your truck runs on the O or the R is pretty dumb! I like real numbers!
Old Jan 20, 2009 | 10:14 AM
Action4478's Avatar
Action4478
Mines blank....I have to use a meat thermometer ...
Old Jan 20, 2009 | 10:17 AM
tjbeggs's Avatar
tjbeggs
Not a bad options. Just don't tell your wife!
Old Jan 20, 2009 | 10:46 AM
WALJON's Avatar
WALJON
LOL thats funny so when your meat thermometer is between medium and well it is running at 200*
Old Jan 20, 2009 | 11:27 AM
Neal 97 250's Avatar
Neal 97 250
Do I dare ask where you stick it?
Old Jan 20, 2009 | 11:38 AM
Action4478's Avatar
Action4478
I could comment ,,but I don't want another red bean...
Old Jan 20, 2009 | 07:26 PM
FARM69's Avatar
FARM69
I concure. I had my stock gauge hooked up for a little bit while I had my aftermarket one. My aftermarket was a lot more responsive and actually moved compared to the stock one.
Plus, I like it in the winter because my aftermarket one starts at 100 F instead of most 140's.
Old Jan 20, 2009 | 09:17 PM
joe_13894's Avatar
joe_13894
The conversion to make it a real gauge is pretty easy. I wrote up my change here: https://www.ford-trucks.com/forums/7...for-gauge.html I didn't write up the change behind the dash, but that's pretty well documented.
VaFordman26
Apr 24, 2013 06:02 PM
EXv10
Sep 7, 2012 04:46 PM
70T351W
Sep 4, 2006 05:48 PM
Sheemie
Nov 30, 2004 07:10 AM
Dyerstown
Sep 22, 2003 07:35 PM
