Pressure switch for gauge?
Old Jul 29, 2008 | 12:10 AM
joe_13894's Avatar
joe_13894
I'm looking to replace my pressure switch with a pressure sender so I'd have a real gauge.
When looking for the right sender, I've dug up that the 80's F series had real pressure gauges or an idiot light. At the part store, they list them as:
-or-
Pressure switch for warning lamp
OK, what's a pressure switch for gauge? That seems like what we have now, a switch with a gauge.... I took the gamble and got one. Turns out, it really is a sender. Open at 0 PSI, clicks at 5 PSI to 90 ohms, and eventually 20 ohms at 100 PSI. That works out about right for the gauges.
Old Jul 29, 2008 | 12:48 AM
BlueMule's Avatar
BlueMule
What year is your truck? On 94 & 95's the pressure switch on the hpop reservoir uses tapered pipe threads but 96's and later use a straight thread with o-rings.
Old Jul 29, 2008 | 04:34 AM
Cuda_jim's Avatar
Cuda_jim
That's good info BlueMule...reps sent.
Hmm? I wonder how many threads I ruined on oil sender's, I don't recall the o'rings on the 94-95's...
Old Jul 29, 2008 | 08:52 AM
joe_13894's Avatar
joe_13894
Thanks for the info BlueMule. It's a '95, so pipe thread should work.
Old Jul 29, 2008 | 10:21 PM
kawa's Avatar
kawa
Good articles Blue Mule, saved and logged.
Reps sent
Rog
Old Jul 30, 2008 | 12:40 AM
joe_13894's Avatar
joe_13894
I decided to try a 45° street elbow instead of the nipple and 90° elbow. I liked the idea of cutting down on the lever arm that the sensor places on the piping by shortening it down some.
Here is the view with the cover off. (Click for a big view.) There is at least 1/2" space between the sensor and cover.
And now with the cover on:
Old Jul 30, 2008 | 12:05 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
You are a very good photografer, and I liked your set up with the 45° streer elbow.
I have some questions:
what is the #part of the oil pressure sensor?
whats is the normal PSI for the oil pressure?, because in the write ups from BlueMule they say that the gauge is 0-90 PSI, and I thougth the pressure was very high, at least 2000 psi, but sure Im wrong.
How is working the gauge?
Old Jul 30, 2008 | 12:57 PM
250turbo's Avatar
250turbo
jose,sensor is on hpop,but is meassures the low pressure before the pump.
kurt
Old Jul 30, 2008 | 06:40 PM
joe_13894's Avatar
joe_13894
As kurt mentioned, the gauge is measuring the main oil pressure.
The gauge reads a little above where it did before above idle. Below idle it reads a ways below.
I hooked the sender up to my air compressor before installing it so I could see the range. It took 110 PSI to max out the gauge. It went low scale about 5 PSI.
I'll add the part number when I get home tonight.
Old Jul 30, 2008 | 08:39 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
kurt
Thanks. OK, but you know wich are the pressure in PSI there?
Thanks too. So I suppose that the rea preassure should be between 5 and 110 PSI according to that, right?, and when you tested with the air compressor, the needle in the half of the gauge was about 50-55 PSI?
And Ill be waiting for the part number
Old Jul 30, 2008 | 08:54 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
I found this for 2004 6.0 L PSD: The minimum engine oil pressure specifications are 82.7 kPa (12 psi) at 700 rpm, 165.5 kPa (24 psi) at 1,200 rpm and 310.3 kPa (45 psi) at 1,800 rpm with the engine at operating temperature. Low or no pressure could be caused by the oil pressure regulator<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
And this:<o></o>
The Powerstroke HP oil pump is fed low pressure oil from the lubricating pump via the HP oil reservoir, located at the front of the engine. Contrary to popular belief, the HP oil reservoir does not store high pressure oil: the oil in the reservoir is at lubrication pressure, 15 to 45(?) PSI , not injection oil pressure (500 to 2700ish PSI.) A more correct term for this reservoir would be HP oil pump reservoir, but everyone seems to leave out the "pump" part, thus leading some people to think the reservoir is holding 3,000 PSI oil.<o></o>
<o></o>
<!-- / message --><!-- sig -->I think this clarify my thoughts.<o></o>
Old Jul 30, 2008 | 11:13 PM
joe_13894's Avatar
joe_13894
Tru-Tech PS60T
Old Aug 1, 2008 | 11:12 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Tru-Tech PS60T
Thanks for the information.
Tifford
Electrical Systems/Wiring
Jun 23, 2017 04:34 PM
caere
Jul 29, 2011 11:07 PM
airjeff
Jun 6, 2011 09:35 AM
F250OBX
Jun 5, 2006 08:33 PM
jimandmandy
Jun 11, 2002 05:06 PM
