Sponsored by: Auxito
vss question
Old Jan 19, 2009 | 09:28 AM
countryboy116's Avatar
countryboy116
vss question
Hey yall im about to start an sas on my 97 F150, i was planning on using a 14 bolt because theyre a little easier to set up as opposed to a sterling, will i have a problem because the 14 bolt is not set up for the vss? I thought that i ahd heard somewhere that the vss tone ring bs didnt do much on the 97, ive also got a sterling 10.25 rear here too that i can use if need be just need to know, thanks for any info yall have
Old Jan 19, 2009 | 08:51 PM
Bobby82490's Avatar
Bobby82490
The early F-150s(97-98) got the speedo reading off of the VSS in the tail shaft. For your application the only thing you would lose is ABS.
Phy
Dec 11, 2014 12:06 AM
302flareside1992
Offroad & 4x4
Jan 10, 2013 10:25 AM
460
Offroad & 4x4
May 14, 2012 06:17 PM
leadmic
Jun 11, 2003 12:42 PM
leadmic
Computer Chips & Tuners
13
Jun 9, 2003 08:46 PM
