Foil Delete Question
Old Jan 18, 2009 | 03:17 PM
mxracer3276's Avatar
mxracer3276
When doing the foil delete, if i leave some of the tape on there with some of the insulation, is there a chance that that could catch on fire?
Old Jan 18, 2009 | 03:30 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Why would you want to leave some on? I don't think it gets that hot.
Old Jan 18, 2009 | 03:42 PM
mxracer3276
Because i took the foil off with the pipe still on the truck and the excess is being a real pain in the a** to get off.
Old Jan 18, 2009 | 04:06 PM
mueckster's Avatar
mueckster
Just remove the pipe and get'r done. The IC pipes aren't that big o' deal to remove.
Old Jan 18, 2009 | 04:10 PM
miller_feed
Yeah, take the pipe off and clean her up.
Old Jan 18, 2009 | 04:30 PM
southpaw37's Avatar
southpaw37
Def take the extra time to get all the stuff off.
Old Jan 18, 2009 | 04:31 PM
joegebff's Avatar
joegebff
Gone Fishin for Mark
There is no fire hazard. But, c'mon man....get'r done.
Old Jan 18, 2009 | 05:37 PM
locknload223's Avatar
locknload223
Remove the pipe and buy a wire wheel that will fit in your drill. Then go to town, that crap will fly everywhere but it's much faster than using GooGone, Gas, or other chemicals.
Old Jan 18, 2009 | 07:12 PM
Izzy351's Avatar
Izzy351
I used Crown Sol-U-Strip from Lowes. Worked like a champ. Here's the thread I started on it almost two years ago:
https://www.ford-trucks.com/forums/5...nsulation.html
Old Jan 18, 2009 | 07:52 PM
Ponyboychris's Avatar
Ponyboychris
Home Depot varnish stripper worked on all the junk Ford put on the IC pipe. Just need to get some elbow grease going.
Old Jan 18, 2009 | 10:26 PM
mxracer3276
No i definitely will it's just that i was in the middle of doing the project when i got a phone call and i needed my truck so i just wanted to make sure there wouldn't be a problem. I will finish it up tomorrow by taking the tubes off and i will paint them and everything.
Old Jan 18, 2009 | 10:31 PM
RussB's Avatar
RussB
I don't think you'll ever catch it on fire !! Drive er' Then get it lookin pretty !
Old Jan 19, 2009 | 06:55 AM
mxracer3276
Alright so the pipes are coming off today. I am going to clean them up and paint them. Do i need any special high heat paint or anything or will regular glossy paint work fine?
Old Jan 19, 2009 | 07:50 AM
miller_feed
I don't think it gets that hot, but the hi-heat would be a good choice. The only thing I KNOW you need is a camera. You know we like pics.
Old Jan 19, 2009 | 07:52 AM
mxracer3276
Of course! Will do Rick. Going to get started on it now so i don't get interrupted in the middle of it like i did yesterday.
