Help Pyrometer Gauge Pegged
Old Jan 18, 2009 | 02:48 PM
captamb1's Avatar
captamb1
Just installed 3 gauges and they all seem to work except the pyrometer, when ignition is on gauge is pegged.When I wired it I ran one wire yellow to #10 fuse(Dimmer) and the red to Constant source fuse #18. Thanks in advance for your help.
Jim
Old Jan 18, 2009 | 06:39 PM
RubberDuck's Avatar
RubberDuck
The yellow wire from the probe should go to the gauge. Wait, before we talk wiring, what type of gauges are they?
Old Jan 18, 2009 | 07:38 PM
captamb1's Avatar
captamb1
Well they are GlowShift so they have different color codes there were two wires coming out of the braided steal jacket off the prob with push connectors one male one female so think I got the male into the female and vise versa. When you turn on the ignition the hand sweeps to the far right then back to 0 then goes to the pegged position to the far right.Thanks for the reply.
Jim
Old Jan 18, 2009 | 08:01 PM
Todd525's Avatar
Todd525
Glowshift........hehehehehehe good luck.............
Old Jan 18, 2009 | 08:03 PM
captamb1's Avatar
captamb1
Be nice Tod
Old Jan 18, 2009 | 09:30 PM
RubberDuck's Avatar
RubberDuck
Okay, is there a light positive (for lights) and key on positive? Maybe those are switched.
Old Jan 18, 2009 | 10:00 PM
captamb1's Avatar
captamb1
I switched them around and when I do that the gauge needle will change as I increase the lights with the dimmer (more illumination) the gauge needle goes higher.
Thanks again
Jim
Old Jan 18, 2009 | 11:14 PM
ftowelding's Avatar
ftowelding
Make sure that your Pyrometer has its own chassis ground, I have helped several of my friends with similar problems. On my VDO guages, I only wired the lights together, all of the guage functions need to be wired seperately. Try it, seems to have fixed problems with pyrometers in the past for me.
Old Jan 19, 2009 | 10:38 AM
captamb1's Avatar
captamb1
Well I want to thank everyone who responded to my plea for help, I isolated the ground and that did not help so I was checking on one of the push in butt connectors and it had come unplugged during the running of the wires.
All is well now,
So I have completed the air intake mod 6637, installed the EGT,Trans Temp and Boost gauges in a "A" pillar mount.
Today my Exhaust is arriving by UPS and after next paycheck will be giving TW a call.
Again a BIG THANK YOU to you guys for your guidance with out the support of this forum I would have been lost.
JIM
Old Jan 19, 2009 | 11:21 AM
c00nhunterjoe's Avatar
c00nhunterjoe
oh boy, PMS has set in with this one....lol
Old Jan 19, 2009 | 06:00 PM
RubberDuck's Avatar
RubberDuck
Glad we could help.
coplin
Mar 7, 2016 05:37 AM
porthole
6.7L Power Stroke Diesel
26
Apr 19, 2011 08:40 AM
Highmark18
21
Jun 12, 2007 11:37 AM
XxfirmanxX
Dec 20, 2005 05:04 PM
motobub
Feb 21, 2003 09:55 AM
