clearance light problems
Old Jan 16, 2009 | 04:27 PM
jake5611's Avatar
jake5611
hi
im replacing the clearance lights on my '79 f-250
i have it all hooked up through an option the new lights instructions gave me where i run a wire from the battery into the cab to a switch, ground the switch and run a lead up to the lights which are all connected
the problem is that the inline glass fuse supplied for the wire from the battery to switch keeps blowing once the voltage is applied and i cant think of a solution
if anyone could help that would be great
thanks
p.s i did a fourm search and none of the threads answered my question
Old Jan 16, 2009 | 04:41 PM
hojolabo's Avatar
hojolabo
I'd say you have one of the white neutral/ground wires crossed. You definately have a short. If those are correct, then check your supply side (black) + wires closely to see if there is a nick in one of them causing the short.
Battery + terminal (black or red) wire to switch-switch to black wire on light(s)- white(s) to a ground. No need to ground the switch, most likely your problem.
Good Luck, H
Old Jan 16, 2009 | 07:19 PM
mark a.'s Avatar
mark a.
Your truck should have the factory plug in. Take the instrument cover off, it's right there by the piller. I'm pretty sure it's brown wire with a plug in.
Old Jan 16, 2009 | 08:00 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Good Luck, H
Um, Automotive wiring is different than House wiring.
Most Comon Colors of house wiring is:
  1. Black (Hot Wire)
  2. Red (Switched Hot)
  3. White (Neutral)
  4. Green or bare (Ground)
House Wiring is less complicated that Automotive wiring, but it is more dangerous due to voltage and amperage concerns.
  1. The Ground Wires on Ford electrical systems is ALWAYS Black. (Only exception is the main battery cables)
  2. 12 volt power supply wires can be any color of the rainbow, with identifying stripes, hashes, or dots.
The stock Clearence lamp socket will have two wires.
  1. Hot 12 volt from headlamp switch. Brown Wire
  2. Black (ground)
Since this is a custom job, we do not know exactly what colors are what for the wires he's chosen.
The most accepted colors for aftermarket automotive wiring: and there are exceptions to even these...
  1. RED: 12 Volt Hot
  2. Black: Ground
  3. White: Ground (Trailer wiring)
  4. Green: (Turn Signal and brake)
  5. Yellow: (Turn Signal and brake)
  6. Brown: (Clearance)
  7. Blue: 12 volt switched, or trailer brake controler
For example though, here is a Simple Automotive circut path....
  1. Wire from battery Plus side to one side of togle switch.
  2. Wire from other side of togel switch to one end of light bulb
  3. other end of light bulb to chassis (ground)
The switch can be grounded by the metal case surrounding it. Do not ground any of the wires leaving the switch, cause this will cause a short circut.
Old Jan 16, 2009 | 09:04 PM
X36's Avatar
X36
Like Hojo said u got a short.I'd guess u nicked a pwr wire when running the wire.I'd start with where it goes through the fire wall or up the A pillar for starters
Old Jan 18, 2009 | 01:48 PM
jake5611's Avatar
jake5611
i worked on the wiring more and i made sure the switch was hooked up right, once it was it only worked to a certain degree and im pretty sure the switch is faulty because it only worked when i held it a certain way
so i went the other route and im using a single action switch with the (unknicked) power wire with an inline fuse holder i put in-- to the switch and a wire from the switch running to the lights with a ground wire fused into the circut at the last light
problem is the same now, the fuse keeps blowing and i am positive there are no shorts its all new wire and i checked it over.
im wondering if i should possibly run it without a fuse in line or if i should ground it somewhere else
any suggestions would be greatly appritiated
thanks
Old Jan 18, 2009 | 02:12 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
In my experience aftermarket lights use the case to ground to the metal so there is usually no need for a ground wire, unless the light is all plastic and in which case you would need a ground wire.
It sounds like to me you are running a wire from the battery, to the switch, to the lights and then this SAME wire you then grounding at the end of the line.
Closed circuit, and bang goes the fuse.
Do you happen to have link to the style of lights you used?
Josh
Old Jan 18, 2009 | 02:50 PM
jake5611's Avatar
jake5611
yeah the switch is all plastic and in on the original switch it had a third prong to ground seperately to metal, but the original switch is faulty.
i went and tried to go without the fuse and the wire couldnt handle the voltage or amperage because it started to melt the insulation
and i am running one wire from the battery to switch and a seperate wire from the switch up to the lights and where the 4th and fifth light meet i fused a seperate wire into the circut and ran it to the cab metal
is it possible im grounding in the wrong place im really lost on this one
electricity is not my specialty
and i dont have a link i bought these lights at an advance auto parts..universals
Old Jan 18, 2009 | 03:12 PM
81-F-150-Explorer
This is one of your problems.
.... and a wire from the switch running to the lights with a ground wire fused into the circut at the last light
It sounds like you are hooking up the lights in series, and they should be hooked up in parallel. Or you are hooking your ground wire into the HOT wire, creating your short.
Here is how it should be wired up...
If it isn't wired like this diagram, then this could be you problem.
Old Jan 18, 2009 | 07:19 PM
Bullitt390's Avatar
Bullitt390
It also sound like the switch you are using is one to trigger a relay. One wire to relay, one to ground and one wire to a 12 volt light source.
Josh
Old Jan 19, 2009 | 12:55 PM
jake5611's Avatar
jake5611
ive discussed the issue with a few more people and this is what i think is going on, its basically a ground issue
from the lights on the top of the cab come only one wire down, that being for the hot wire to connect, basically what ive been doing is creating a direct ground for my wire by bringing my grounds into the hot wire as said before (im not sure by who)
so what i think im going to do is take a look directly at the lights and see how they are grounding im not sure if they are using the lights themselves mounted to the cab to ground or not, but the lights housings are all plastic
i may go ahead and try to match the original switch that was faulty and try and re-wire it in the same way with the three prong switch that 1.has wire from battery with fuse running into switch 2. has ground off second prong to body right next to switch 3. has wire from switch up to the light leads
if you guys have anymore help or ideas give me a shout
thanks for all your help so far....makes it easier than shooting in the dark
Old Jan 19, 2009 | 03:08 PM
81-F-150-Explorer
This is your short. Remove that ground wire.
You need to hook the hot wire from the switch directly to one side of the light bulbs. Do not ground this wire at all.
You hook your ground wires to the other side of the light Bulbs.
Power goes directly to the bulbs, goes through the bulb, and grounds on the other side.
The diagram in my previous post shows this clearly.
ASizzle
2009 - 2014 F150
Jan 2, 2011 10:19 PM
peckhamjusten
May 31, 2008 02:15 PM
wbtguy
Electrical Systems/Wiring
Nov 4, 2004 07:49 PM
firsttimeFordowner
Aug 16, 2004 01:07 PM
