CPS sounds very plausible. The fact that you sprayed starter fluid into the air cleaner while cranking and didn't get the truck to at least run briefly would indicate you have no spark. Without the CPS< the PCM won't be ab;e to tell the COPs when to fire.
The fact that you sprayed starter fluid into the air cleaner while cranking and didn't get the truck to at least run briefly would indicate you have no spark. .
not true. as i said before, my 2000 would not fire or even burp on ether when the fuel pump went. there was nothing wrong with the ignition system though.
to access the relays under the dash, pull the radio.
I agree check your intake when i was putting in my cold air i was messing with the sensors on the intake and disconnected one. I started it and it ran great for a few mins and then died plugged it back in and it started right up. Also my coils have started to go out and they are going out one at a time. Even with two or more out my truck still ran or it could be the solenoid on the starter.
Also when my first coil went out i talked to a lot of people and everyone said something different but they said if it was a miss fire the check engine light would come on. But when it came down to it was a miss fire and the check engine never came on and i also had it plugged and scanned. So what i am saying is just because the check engine light does not come on does not mean you are getting spark or something else.
a coil misfire will not always trigger a misfire code.
if it is a once in a while misfire, it will not throw a code. most of the time it will only throw a code when the coil dies.
The old OBD11 (2) systems, which used to be on all cars in the late 90's and since gone outdate but a similar system is still used on all cars.
A misfire is always detected but also catagorized. So it can be seen or considered as to its relivance. Although it does throw a code it cycles out of the computers current reading but can be seen, and refferred to a a ghost, or a shadow. Meening just that . Old problem but sytem corrected.
Sometimes that very circumstance can lead a tech to a possible fault or cause. If a coil is going weak, The computer will offset the injector, to still attempt to get a good or close to good cylinder burn.
That is why the old cars, (points, carbs ) ect would leave you stranded. These new cars may still leave you strnded but mostly help you at least get home, although with a check engine light, be it yellow or red
A misfire in these trucks will cause a PENDING CODE. You usually won't get an actual code or a CEL from a misfire caused by a bad COP, bad boot or a bad plug.
This is why you need to use a scanner that can pull the pending error codes.
and like i said, a occasional coil misfire will not always throw a readable code.
the coil has to damn near fail before it will throw a CEL
code.
i can't tell you how many times i have had to wait for a coil to get worse before i can change it, because it will not throw a readable code, but i know i have one going bad because of an occasional misfire.
Crank and cam sensors would show a code wouldn't they? They did on my 02'. Crank sensor rides real close to the A/C compressor and the wire harness could possibly have rubbed through.
I would think so but when my coil goes out it never throws a code I had to drive from ft collins to durango thats about 350 miles running on 7 cylinder and i never got a code and it was running bad.
