Weird fuel leak
Old Jan 15, 2009 | 04:34 PM
frenchslandscape's Avatar
frenchslandscape
Weird fuel leak
I don't know what its called but it looks like a valve stem near the fuel filter and there is an air/fuel mix coming out of the valve stem type thing.
Old Jan 15, 2009 | 08:35 PM
joe f350's Avatar
joe f350
thats a bleader valve if remember right ur truck us to be a fleat truck
Old Jan 15, 2009 | 08:59 PM
1dieselman's Avatar
1dieselman
That's a fuel priming valve, uses the same valve core as your tires and should have a good quality cap on it. Also is the fuel return line hooked from your filter down to the fuel return lines usually #1 injector?
Old Jan 15, 2009 | 09:00 PM
EMD_DRIVER's Avatar
EMD_DRIVER
It's called a schrader valve and it's used to bleed air from the fuel system. It's also helpful in checking the volume of fuel that your lift pump is flowing. If the valve is leaking, you can try replacing the valve stem itself. You could probably get one from a tire shop. Most shops will give you one for free, but they may charge you for it. They couldn't cost too much.
Old Jan 15, 2009 | 10:31 PM
joe f350's Avatar
joe f350
but y is it wore out did the pervers owner run it out of and use that valul alot and thats not good
qman
Dec 8, 2014 11:56 AM
Bigfootgrey
6.7L Power Stroke Diesel
Aug 30, 2013 04:40 AM
Chumbucket
Jan 10, 2006 04:20 PM
rvpuller
Jun 22, 2005 07:11 PM
GeneStoner
Oct 23, 2002 03:25 PM
