Thanks for the comp. I don't know how heavy your camper is, but i pull a 20 foot boat and there is no sag at all. Unfortunately i don't have any pictures with the boat on there. I dont know if i don't get sag because of the DRW or not but.
...Yeah Pete, i had thought about going with the 2 1/2 inch as well but a buddy of mine cam over with his tape measure and measure how much the difference was from front to back. The only thing is i forget exactly what he measured. Sorry couldn't be more help.
I've measured about 3-1/2 inches difference between the front and rear wheel opening on my truck, which is also 2WD with front coils. I do know from what others have said, though, that due to the geometry of the front end and where the spacer goes in the lineup of things, you actually get something like 2-1/2 to 2-3/4 inches of lift off a 2 inch spacer. That being the case, the 2-1/2 inch spacers may be a little more than ideal in final lift effect.
Yeah that definitely makes sense. So after doing the measuring though i still wasn't sure and kind of just took a shot in the dark and hoped that it looekd good. Judging by the feedback, it looks alright.
OK... so you gained 2-1/4 inches with the 2-inch spacers. That means that the 2-1/2 inch spacers will probably provide a little more than 2-3/4 and still leave about a 1-inch difference between the front and rear openings.
I gotta think about this, now. I know that with one ton of sod in my bed, the truck still sits a tad high in the rear. Given that I never tow anything, I guess the 2-1/2 inch spacers will level it a bit more, but will also probably hurt mileage a little more than the 2-inch spacers. I'll mull this over a bit. Good info!
Yeah if you rear still sits higher with 2,000lbs in your bed then i would go with the 2 1/2. The only thing is it may still be too much, and i would rather be still a little lower in the front and higher in the rear then higher in the front and lower in the rear ya know...
Thanks again, Matt. I agre about having the tail up a little, too. I also have a neighbor who owns some CNC equipment, and I need to talk it over with him to see if he can machine the sapcers for me at a much lower cost. I've priced some 2-3 inch thick flat bar stock, and it really would not cost much in amterials to even get the spacers out of either stainless or tool steel.
If he can do it, I'll see if I can help him get set up to start making them and selling them online... he needs some more business right now anyway.
Ah man that would be great. Especially selling them for even just a little less then actual cost i think you'd do great. Great idea man.
I think I'll probably let YOU get the spacers first, and I'll be getting my truck two-toned! I got the cash, the body man is picked out, his price is right, and it's going to happen within a month... along with paint matched Bushwacker Street Style fender flares, which just arrived late last week... still planning on using the dark gray/flint color. Gonna be real nice... pics to follow.
