87 250 diesel
Old Jan 13, 2009 | 05:54 PM
frostysdriver's Avatar
frostysdriver
87 250 diesel
how hard would it be to put 350 running gear under it?
and how much should i look at spending to repair a crack on the top of my radiator? would it be cheaper to get a new radiator?
Old Jan 13, 2009 | 06:00 PM
frankyford's Avatar
frankyford
Are you looking to put in a dually rearend? Depending on what year your donor truck is, shouldn't be hard at all. Their all pretty much the same drivetrain, your just swapping it from one truck to another.
Old Jan 13, 2009 | 07:19 PM
tjc transport's Avatar
tjc transport
i ain't rite
if you are talking about a 4X4 front end, the Dana 60 front axle swap is a straight forward bolt in. two men, 6 hours, and a six-pack of your favorite frosty beverage.
if you are talking about a 2 wheeler, the 250 and 350 use the same suspension parts.
as far as the radiator goes, i replace them instead of trying to fix them. you fix one leak, and it is only gonna start leaking somewhere else.
Old Jan 13, 2009 | 10:02 PM
frostysdriver
new question
frosty is a 4x4, im not sure what my husband was thinking about doing this for. we talked about it a long time ago.
now i have another question.
the powerstrokes you can chip, my truck has the 7.3 but it is an indirect injected system rather than direct injection. my husband is in diesel mechanic school now with the navy (seabee) and he says they are almost identical(beside the fancy name and the fact that the powerstroke came with fords turbo instead of the after market banks one on mine) so, can you chip the '92 indirect injected 7.3l?
Old Jan 13, 2009 | 10:32 PM
Dean88's Avatar
Dean88
With all due respect, the 7.3 idi and the 7.3 Powerstrokes are two completely different beasts. Some of the 93-94.5 7.3 idis actually came with a factor turbo, but they weren't called Powerstrokes.
Its one of the reasons I hate the metric system of measurement, Because the 7.3 idi is a 446 cu, and the 7.3 Powerstroke is a 444, but the idi's don't have any computers at all, they are a mechanical motor. The only similaraty between the two motors is the mounts are the same along with the bellhousing pattern.
Old Jan 14, 2009 | 06:35 AM
tjc transport
i ain't rite
the benefit of swapping a F350 Dana 60 front end in is to get rid of the problematic IFS system.
it gives you a stiffer ride, but is a much stronger system
as Dean said, the IDI you have is a completely different animal than the powerstroke. and there is no computer to put a chip into.
since you have a banks turbo setup on your truck, it is better than a powerstroke anyway.
a banks equipped IDI will throw down higher HP and torque numbers than a powerstroke.
Old Jan 14, 2009 | 10:51 AM
frostysdriver
My bad, now that i think about it he did mention the computers, and i didnt know that my engine is 2 cubic inches bigger than the powerstroke.
Old Feb 1, 2009 | 06:59 PM
frostysdriver
OK! I talked to my husband and i cleared up what he was wanting to do with the truck and rear end crap.
It was so long ago i couldnt remember exactly what he was saying, but i remember now!
He wants to put 350 leafs in the back and my back leafs in the front. I know, totally different than what i originally said, but now that i have it cleared up, here we go.
Old Feb 1, 2009 | 07:28 PM
1994 F250: 351, C6's Avatar
1994 F250: 351, C6
Your rear leafs will not work in the front of your truck. Among other things they are wider than the front springs.
kupiec20
Jan 19, 2015 11:05 AM
Desarata
13
Jun 10, 2013 04:49 AM
diablodude64
Feb 24, 2012 11:13 PM
Lance Hogan
Oct 22, 2010 02:53 PM
