radiator support question
Old Jan 18, 2015 | 04:52 AM
kupiec20's Avatar
kupiec20
is it possible to swap out a radiator support without removing the radiator?
if so how to?...
ty
Old Jan 18, 2015 | 05:23 AM
ProjectDually's Avatar
ProjectDually
Why wouldn't you want to remove the radiator? I mean, it's only like 10 bolts that hold it on there.
Old Jan 18, 2015 | 06:41 AM
kupiec20's Avatar
kupiec20
wasnt sure. fitst time doing this.
also i know there is a small radiator thingy for the tranny.
whats the medium size one for?
Old Jan 18, 2015 | 07:10 AM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
A/c condensor
Old Jan 18, 2015 | 10:40 AM
madpogue's Avatar
madpogue
The tranny fluid cooler is inside the radiator (automatic transmission only).
Old Jan 18, 2015 | 03:06 PM
kupiec20's Avatar
kupiec20
anything i need to know aboit taking out a radiator?
pretty strait foward?
Old Jan 19, 2015 | 10:06 AM
ProjectDually
Yea, you'll need to undo the fan shroud, to get it out, take the rad hoses and coolant overflow hose off, drain it, and there are some bolts to undo it from the core support. After that it's pretty simple. While you have the core support off, are you changing out the water pump and fan clutch? Would be the easiest time to do, it short of pulling the engine off.
Old Jan 19, 2015 | 11:05 AM
madpogue's Avatar
madpogue
Put a sheet of cardboard between the fan and radiator, so if the radiator moves or slips as you're removing it, it won't fall into the fan.
kenny nunez
Aug 5, 2017 12:17 PM
xjpilot
Dec 10, 2013 08:06 AM
frankydabull
1947 and Older Ford Trucks
Mar 8, 2004 06:14 PM
