Dual Alternator Bracket for 1997 PSD - FL
I would like to add the second alternator to my 1997 PSD so I can charge batteries in my slidein P/U camper. My local dealer does not appear to have the information I need to acquire the bracket for the second alternator commonly referred to as the Ambulance option. Does anyone have part numbers to add this option. Are there any after market sources for the bracket and associated hardware.
Thanks,
pbgsho2
Thanks,
pbgsho2
Hey I was thinking of the same thing............for putting a rv air conditioner on my camper shell for my dogs.........using a inverter and stuff.........a extra alternator may put a lot more drag on your engine.........how about a bigger alternator to charge those batteries.........if you look around there are places making really big alternators to replace your original one that will put power into those extra batteries...........seem to remember they are about 400.00 or so...............I'm going to replace mine when my original one goes bye bye or I find a cheap RV unit which ever one comes first.
on
Dual alternators were not an option on the OBS. The alternator package consisted of a HUGE case 215 amp alternator. It fits the stock location with some trimming of the bracket but it bolts right up. It requires a belt that is a 1/2 inch longer and also requires some wiring changes. I will post some more info on it tonight when I get home
Seems I remember seeing a belt routing diagram that showed 2 alts on a 7.3L. Would that have been for a Super Duty? Why wouldnt it work on an OBS?
on
Yep dual alts available on the SD but not on the OBS.
Pictures for the swap
215 Amp Alternator and New Battery Cables pictures from friends & fun photos on webshots
Threads on the swap
215 amp alt belt - Diesel Forum - The Diesel Stop.com
high amp alternator - Diesel Forum - The Diesel Stop.com
Complete details on 215 Amp alternator mod... - Diesel Forum - The Diesel Stop.com
215 amp alt. part # - Diesel Forum - The Diesel Stop.com
130A to 215A alternator swap questions - Diesel Forum - The Diesel Stop.com
Threads on the swap
Its a Ford 3G alt rated 130 amps.
I have seen (never used) kits to upgrade the 3G to 200 amp.
HD Reg and rect is needed.
RJM Injection Tech Alternator Accessories & Parts
Bill
Bill
on
Bill
Bill
Dont know anyone that has used it.
Every 3G failure here has been from the brushes
wearing thru the copper ring.
Bill
