Sponsored by: Kumho
auto zone quality
Old Jan 12, 2009 | 08:30 PM
tonebone's Avatar
tonebone
auto zone quality
I felt it was wrong when I did it...But I did it anyway. I went cheap and purchased front rotors from auto zone. I saved 60 bucks on the pair. I have had to turn them twice so far at about 30.00 a time. you do the math. how can they sell items that are so inferior??Or did I just get a BAD set from them??....Tonebone
Old Jan 13, 2009 | 08:07 AM
Gevans17's Avatar
Gevans17
Well, you knew it was wrong when you did it!
Old Jan 13, 2009 | 08:40 AM
ghunt's Avatar
ghunt
Chinese junk, man...what do you expect.
Old Jan 13, 2009 | 09:23 AM
brian42's Avatar
brian42
Veteran: Navy
It's simple math:
Ford trucks are hard on brakes + low end rotors are not very heavy duty = save some $$$ now
-and-
Save some $$$ now + low end rotors = more $$$ in the long run
I had a '97 2wd F-150 and I burned through a set of front rotors every year. They weren't even worth turning because they were either run down too far or badly warped (and I'm a pretty mild driver). It was not cheap because that truck had integrated hubs with the disc (all one unit) so I was looking at $250 in OEM rotors every year (not even aftermarket).
It's worth the investment up front for a good set of rotors (cryo treated if they are in your budget, they are more warp resistant) and pads for Ford trucks.
Old Jan 14, 2009 | 03:07 PM
bashby's Avatar
bashby
They should be lifetime warranty, why spend $ on turning them. I have installed tons of them with few problems
Old Jan 16, 2009 | 08:43 AM
b2_tim's Avatar
b2_tim
Like most parts store there is a choice
I have found over the years their quality is OK. I almost always get the lifetime warranty stuff well worth it over thier cheaper line. I havn't had to buy brake pads or mufflers in years, just take in the worn out ones and get new, never a hassle. SInce I keep my trucks 4 ever, and ride em hard, this works out in my favor.
Very few parts I have bought have been junk.
Old Jan 16, 2009 | 12:05 PM
focusdriverlx20's Avatar
focusdriverlx20
honestly, OEM or a quality national brand is the way to go, differences in the metal composition is what makes the rotor good or bad. Brembo off of tirerack would be a greeat choice. or OEM.
Old Jan 16, 2009 | 08:51 PM
rmo1's Avatar
rmo1
Did my front brakes a few weeks ago. Bought Brembo plain rotors ($94/each) and Hawk LTS pads ($84) from TireRack.com. So far so good. Took it easy braking for the first 200 or so miles.
Bob
Old Jan 18, 2009 | 08:05 PM
micgang's Avatar
micgang
Often find good deals at places like Rockauto.com. They usually have a good selection of national brands, plus some off brands. I have had good success in getting Raybestos brakes pretty cheap... Only rotors that I regret buying were some PepBoys rotors for the rear of my 02 Explorer. They were soft and were pretty useless after about 2 years...
Old Jan 30, 2009 | 01:36 PM
Damon_Tirerack's Avatar
Damon_Tirerack
Former Vendor
I solve OE or OTC rotor issues all the time by switching people to Power Slot rotors. Ford is moderate, but GM quality is even worse. If you saw the porosity of the stock rotor castings under magnification you'd see why they warp so fast. Spend a little more on rotors, and you'll get it all back in the future - guaranteed. Give me a call if I can help.
Old Apr 19, 2009 | 05:56 PM
HICKatvRACER17's Avatar
HICKatvRACER17
just make sure they give you the right ones!! haha
Old Apr 20, 2009 | 07:35 AM
fordboy67's Avatar
fordboy67
I tried the Powerlot Cryo rotors with Hawk LTS pads, could not get them to work, kept pulling to the left, replaced lines, slide pins calipers, everything, still pulled. Replaced powerslots with Raybestos rotors...NO PULL, and half the price. Just my experience.
Old Apr 23, 2009 | 04:15 PM
Damon_Tirerack
Former Vendor
Sounds like a dragging caliper. The Raybestos rotors may have been a bit thinner.
Old Apr 29, 2009 | 11:57 AM
liftnw8z's Avatar
liftnw8z
AutoZone (and Advance Auto too while we're at it) have given me mixed results. Sometimes really good, sometimes really bad. The last set of brakes I did (maybe 8 months ago? ) on the Explorer were from AutoZone and I feel like I've got to redo them already...the pedal's feeling spongy again. I'm going to do something different next time - just not sure what yet.
Old Apr 29, 2009 | 03:14 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Did you "break-in" these new set of rotors/pads after you installed them? Do 4 very hard stops from about 60 down to 5MPH, but DO NOT STOP..... you should smell them by now....drive for a mile or so to cool 'em down. Will last for a very long time.
tonebone
2004 - 2008 F150
Jun 12, 2011 04:15 PM
tonebone
Mar 1, 2010 02:30 AM
tonebone
1997 - 2003 F150
Sep 6, 2006 05:24 PM
tonebone
Modular V8 (4.6L, 5.4L)
Feb 17, 2005 02:21 PM
tonebone
Jan 24, 2005 10:27 PM
