hitch mounting
Old Jan 12, 2009 | 07:48 PM
TxFordGuy's Avatar
TxFordGuy
hitch mounting
i bought a receiver hitch off a guy and it came with 4 bolts and a plate that the bolt screw into for the top side. does both sets of hole have this plate or can i just use some bolts with washers? i bought grade 8 1/2" bolts with grade 8 nuts, and grade 8 washers. will these be ok? and should i use lock washers?
Old Jan 12, 2009 | 07:52 PM
strickracing's Avatar
strickracing
if your not gonna go the lockwasher route take and tighen the bolts tight and put a punch at the threads where they come out of the nut and smack 2 spots on each bolt to help prevent
the nuts from coming lose
Old Jan 12, 2009 | 08:10 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Grade 8 bolts are good for this. If not lock washers, use lock nuts.
MattyP10178
Apr 7, 2016 07:06 AM
benbuilder
Dec 12, 2015 07:24 AM
wvmudder
May 18, 2007 07:23 AM
SoTX yellow
May 19, 2004 09:49 PM
dbrown13
Apr 9, 2004 09:21 AM
