Exhaust Manifold Bolts-Reuse?
I am installing the exhaust manifold back on the engine. 77 302. Can I or should I reuse the old bolts? I see autozone has a new set for 30.00 and some other place has a set for 100.00. Not sure the difference. Or can I get grade 8 bolts and install them with lock washers? thanks
Nord-Lock are 2 separate washers with teeth that face each other when installed and torqued, never loosen up.
Nord-Lock wedge-locking washers | Secure your critical bolted joints with the original lock washer from the bolting experts
Sears, Northwest tool, Fastenall, I always use them on my exhaust manifolds. And look into Remflex exhaust manifold gaskets or the ones JBG sale. Both are very good and no chance of an early burn out.
Make sure that the mating surfaces of the head, exhaust manifold and your hands are oil and grease free when installing them. Any contaminate to the gasket can cause a burn out.
dthut
03-16-2017 10:50 PM
Johno.h
07-19-2015 07:02 AM
greeneon_01
08-03-2010 10:24 AM
78blueford
02-05-2003 09:10 PM
