Sponsored by: Real Truck
Oil Leak ?
Old Jan 12, 2009 | 03:38 PM
budcocustom's Avatar
budcocustom
Oil Leak ?
On my 02 F350 7.3PSD i have an oil leak on the engine. I degreased everything and noticed that the oil is collecting in the vally pan. it looks like it is comming from the bottom of the turbo area. Does anyone know where it might be leaking from? looking for a few pointers.
Thanks
Old Jan 12, 2009 | 04:21 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
It could be a couple places. One is the o-rings between the turbo and pedestal, or, pedestal and block. Could be the rod for the EBPV. You need to look very close to find a leak on the back side of the valley. It also could be the orange boots under the spider going into the manifolds.
Old Jan 12, 2009 | 08:44 PM
CobraGT40's Avatar
CobraGT40
Thanks
My 2000 F250 7.3 did the same thing...when you park and look underneath, the oil looks like its coming out the weep-hole for the flywheel cover ? I thought it was the rear main seal leaking at first until the guys here at FTE told me about the HPOP (High-Pressure Oil Pump) seals leaking...same symptoms you described. As far as I know its a very involved process and the dealership wants a mint to perform the surgery. I have a trusted mechaninc that replaced all of mine for under $300. If your ever in N. Illinois I can get you his number LoL
Good luck !
Scott
Old Jan 12, 2009 | 09:03 PM
F350-6's Avatar
F350-6
Good luck !
Scott
Actually it's usually a simple process that requires less than $5 in viton o-rings. You two should stop by the 99-03 7.3 diesel section a little further down the main forum listing. Plenty of knowledge about these motors down there.
Old Jan 5, 2011 | 10:04 AM
Sarge0311's Avatar
Sarge0311
Scott . I live in Aurora and the same thing is happening to mine . I dont have the garage space to take it on . If you could give me the Mechanic info then I'd realy appreciate it . The oil is just about pouring out now ,
Thanks ...... Sarge
newBstroker
Feb 9, 2011 01:43 PM
Spirit615
Aug 29, 2006 07:17 AM
ford390gashog
Nov 20, 2004 10:35 PM
redygo
Feb 12, 2004 08:39 PM
GeoTracker
1978 - 1996 Big Bronco
Feb 11, 2004 03:55 PM
