1978 - 1996 Big Bronco
Oil leak
Old Feb 10, 2004 | 05:32 PM
GeoTracker's Avatar
GeoTracker
Oil leak
I'm looking under the Bronco and I see load of oil under there. I'm not super low on oil but I do need to put in a quart every couple of months. Now from the looks of things it may be the oil pan but I'm also noticing oil higer up on the block. Is it possible that a leak from the pan can splash oil around that much?
Old Feb 10, 2004 | 07:52 PM
Lobuck76's Avatar
Lobuck76
If it is coming from up high, I would check valve covers first,(easeir said than done) Look for spots that look a little too clean.
Old Feb 10, 2004 | 11:38 PM
jims89bronco's Avatar
jims89bronco
check the oil pressure sender...drivers side just above the oil filter. It's a common leak area...since it's under pressure, and with the fan blowing air all around, oil can splatter everywhere. Anyone that has had a leaking oild sender can verify this!
But check the valve covers too...and then work your way down.
Old Feb 11, 2004 | 03:20 PM
GeoTracker's Avatar
GeoTracker
Well it looks like it's going to be a pain to track this leack down. I swapped out the starter today and noticed that there's oil dripping by the tranny too. The valve covers are showing some oil too. How hard is is to change out gaskets? Or is this a job better done by someone else?
As for the oil sender, is that an easy fix?
Old Feb 11, 2004 | 03:55 PM
JBronco's Avatar
JBronco
The oil sender is very easy. Valve cover gaskets with a fuel injected engine are a pain in the butt. You will have to remove the upper intake.
kj2wilson
Mar 29, 2014 02:11 AM
VH_Girl
24
Feb 27, 2012 08:48 AM
kottkeyk
Aug 25, 2011 10:57 PM
goldsmje
Mar 10, 2008 12:32 AM
Roguespirit
1983 - 2012 Ranger & B-Series
Nov 20, 2006 03:50 PM
