oil leak
Old Oct 29, 2004 | 01:39 PM
ford390gashog's Avatar
ford390gashog
oil leak
i have a odd oil leak it is coming from the back passenger side in the back and is dripping oil all over it looks to be coming from where the intake meets the head is there any way this could or can it be the rear intake seal
Old Oct 29, 2004 | 05:45 PM
stephenw's Avatar
stephenw
Look at your VC gasket first!
In my experience, a VC (valve cover) gasket leak seems to be able to "move" all over the place and mislead, and almost always a new VC gasket has cured the symptom you describe. Be sure that you put a little dab of RTV at the mating point of the head and intake manifold too, as that's a real likely leak source.
A disclaimer tho, I did replace the intake manifold gaskets too, or should I say, did them with using only "The Right Stuff" RTV for the valleys. It really is some good goo! Steve
Old Oct 29, 2004 | 05:50 PM
debestuss's Avatar
debestuss
Same here. I put RTV on the bottom rear corner of my valve covers now, from about half way to the front on the bottom and up about 3 inches up on the back. I had a terrible oil pond under my truck until I did that. If your valve covers are old, the holes where you put the bolts are probably sunk in and some of those braces might be in order, too.
Old Oct 29, 2004 | 06:39 PM
ford390gashog
this engine is a fresh rebuid
Old Oct 29, 2004 | 07:00 PM
stephenw's Avatar
stephenw
Did you RTV the valleys, or use cork?
If you overdid the RTV at the matching point between the valley and side port gaskets, or used too much if using only RTV on the valley, it's possible that it's blocking the oil drain channel from the rear of the head and overflowing. I'd still bet on a VC leak tho, and it's a lot easier to check and try a replacement than to pull the intake with the engine in the truck. You might be able to see a leaky spot on the VC gasket if you are careful removing it? And again, be sure to dab the VC flange match line between the intake and head.
Good Luck! Steve
Old Nov 16, 2004 | 11:46 PM
edsf100's Avatar
edsf100
RTV? need help please.
Old Nov 17, 2004 | 12:10 AM
ford390gashog
it was the intake not matching right i replaced it with a edelbrock
Old Nov 17, 2004 | 12:18 AM
edsf100's Avatar
edsf100
I been reading up on the leaks from the rear of the intake. I have this problem on my 390. Though it was the head gasket but after reading up on this I try the RTV blue. I have a edelbrock intake also. Do you know the specs for the intake bolts?
Old Nov 17, 2004 | 04:14 PM
Billy4416's Avatar
Billy4416
I had the same problem with my 390. The oil just poured from the back of the intake. For a temp fix I cleaned the oil off as best as I could with brake cleaner, then just gobbed the RTV Blue on it and worked it in real good. Leak stopped. Since then I replaced the intake but made sure I put plenty of sealer on the back gasket. No leaks. Actually learned about this from someone in this forum.
Old Nov 17, 2004 | 04:41 PM
edsf100's Avatar
edsf100
Thumbs up
Thanks! I've learned a lot about this subject in this forum.
Old Nov 20, 2004 | 10:35 PM
edsf100's Avatar
edsf100
the black rtv did the trick. no more oil leak
stopp429
Jun 10, 2013 07:09 PM
robjs111
Feb 23, 2011 09:56 AM
onebadb1
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
May 7, 2010 11:15 PM
cradar69
Jan 15, 2007 12:09 PM
jpjahn
Jul 25, 2005 11:15 AM
