Sponsored by: Real Truck
Front End Noise
Old Jan 12, 2009 | 09:21 AM
kdexter's Avatar
kdexter
Front End Noise
I Have a 02 F350 7.3 SWD 4x4.. I have a roaring noise coming from the front end.. I think... I just replaced all the ball joints, u-joints and 2 new front hubs(Ford)..also installed new pads and turned rotors.. Could one of the hubs be bad or what else can I look for..Going to check and make sure caliper is'nt dragging.. running out of options...
Old Jan 12, 2009 | 09:45 AM
Vankaye's Avatar
Vankaye
I had a similar noise. It was the needle bearings. Sounds like your running on rough asphault right? Comes and goes?
Somebody may be able to more better articulate the technicallities but
they were the bearings for the shaft right just before the hub. I thought it was my hubs too... but it was only a $100 repair.
Old Jan 16, 2009 | 10:03 PM
Steve_250's Avatar
Steve_250
More info needed:
What speeds, gears, load, etc?
Getting on the throttle, constant, letting off?
Road condition?
Can you manually op the hubs?
Sure it's not the trans fan coming on?
Old Jan 16, 2009 | 11:05 PM
mnpowerstroke99duty's Avatar
mnpowerstroke99duty
I have had calipers slides stick and drag ,make noise. Sometimes after a brake job the pistons decide they don't like too be forced open, too install new pads and start sticking.My truck did this two different times.I'd drive it a few miles and get out and see if either side gets hot.
Eastland
Dec 7, 2011 01:43 PM
jcheadle
Dec 12, 2008 12:03 PM
1954F250
Oct 22, 2006 07:39 AM
