Speedometer cable replacement
Old Jan 11, 2009 | 08:24 PM
barbsbuddy's Avatar
barbsbuddy
I need to replace the speedometer cable in my '76 F-250. What is the proper way to disconnect the cable from the speedometer head? Can it be done without pulling the dash apart? Any special tools? Thanks for your help.
Old Jan 11, 2009 | 08:33 PM
460's Avatar
460
To disconnect it - there is a white color plastic collar that locks the cable onto the head. You have to push the connector to the side and the cable will slide out then. The cable should come out fairly easy. I have a good pic on my computer at home that I can post when I get there.
I don't think you need to pull the dash out to get it, as long as you can fit on the floor and reach your arm up there.
Old Jan 12, 2009 | 01:18 AM
bucks77ford's Avatar
bucks77ford
Old Jan 12, 2009 | 03:56 PM
barbsbuddy's Avatar
barbsbuddy
I got it done. I had to open the dash, maybe because of the AC ducting.
Old Jan 12, 2009 | 08:59 PM
polaris21's Avatar
polaris21
Thats actually helpfull. I will be replacing mine soon 2.
Old Jan 13, 2009 | 08:19 AM
nikm7's Avatar
nikm7
Where did you get your cable from. I am in need of one.
Old Feb 15, 2009 | 02:48 PM
dgriff's Avatar
dgriff
Great video! Thanks, very helpfully in getting mine out.
