Ecm
Old Jan 11, 2009 | 05:47 PM
tommyii77's Avatar
tommyii77
Ecm
I just hooked up a tach to my 1995 f150 with lots of motor mods and the revlimiter cuts out at 5000 rpm. is there any thing I can do with that. Help would be appreciated.
Old Jan 12, 2009 | 09:04 AM
Conanski's Avatar
Conanski
It's probably not 5000rpm, have you calibrated the tach?
Old Jan 12, 2009 | 10:54 AM
tommyii77's Avatar
tommyii77
What do you mean? Its set on 8 cylinder. Is there something else I can do?. thanks again.
Old Jan 12, 2009 | 11:03 AM
Conanski's Avatar
Conanski
Most aftermarket tachs have an adjustment on them and are not always very accurate out of the box. To calibrate the tach you need to connect an oscilloscope or automotive DMM that measures RPM to the tach output on the motor and adjust the aftermarket tach to corresponds with the actual rpm the motor is turning.
Old Jan 12, 2009 | 11:50 AM
tommyii77's Avatar
tommyii77
Thanks alot I'll try and figure that out. You've been a great help. I'm glad to have joined this site.
russellkr
Nov 2, 2002 11:18 AM
beartracks
Oct 18, 2002 02:20 PM
dale i
Sep 22, 2002 09:37 AM
rogwelch
Feb 12, 2000 11:29 PM
Jan 28, 2000 06:08 PM
