polished fender bolts, what to do?
#46
Sam, I dont know if this will help your situation or not....but I purchased all of my bed hardware from Boltdepot.com
The strip bolts are not hidden, what I got were the SS-button head bolts for the bed and fenders...boltdepot might have something that would help solve any issues you have???
ps....I love the green!
Ed
Ed
and thanks (on the boltdepot info)..
I am really torn here.. I want the flat polished faces, but am not really excited about the filing the holes open.. (estimate 10min *24 holes= 4 hours)..
Sam
#47
on
The flathead would work best if your fenders had an oversized hole or if it were chamfered on the side facing the bed. If you don't do this the angled back of the head could be accomodated by using SST finishing washers or chamfer the ID of regular SST washers.
Personally I would use the SST button head bolts. They are better looking than your flat head carrage bolts or the flat head socket bolts noted above. They have a smaller diameter and don't require any modifications to your bed or fenders. For me it's a "no brainer".
#48
well, I gave in and ordered the button head from MF which came this week.
ick!... but, I had used a few stock bolts with the dimples when I put the fenders back on after paint.. a few left dimples in the paint around the holes.. (bummer)..
and it turns out, the button head bolts would NOT hide the dimples!!!.. SO, back to the polished flat face bolts with the carriage head base..
So, yesterday I went and found a decent file, and it wasn't as bad as expected.. 1.5 hours for 20 bolt holes. I painted the freshly cut edge of the holes (had to do this in two passes, else I would have had to remove the fenders altogether)..
man they look nice!.. (pictures later)..
Thanks for all the guidance..
sam
#49
#50
Sam
#51
sam
sam
#52
Thanks AX.. that time was elapsed.. cause I had to stop for dinner and loow the first 14 holes to dry put in the new bolts, remove the old, file, paint, and dry.. so that is the filing time.. it was a lot easier than I expected, and none of the paint peeled around the holes... frosties next weekend when I get the running boards & tailgate back from re-paint (I hope!).. and I found the stain color for the wood.. now to get that done too... Sam
#53
hm.. edit no worky
Thanks AX.. that time was not elapsed.. cause I had to stop for dinner and allow the first 14 holes to dry, put in the new bolts, remove the old, file, paint, and dry.. so that was the filing time.. it was a lot easier than I expected, and none of the paint peeled around the holes...!
Sam
Sam
#54
sdetweil
01-02-2012 08:07 PM
sdetweil
22
04-30-2009 12:39 PM
sdetweil
13
02-08-2009 10:50 AM
sdetweil
16
04-26-2006 08:16 PM
sdetweil
04-21-2006 01:45 AM
