running board alignment
Old Apr 23, 2006 | 08:39 PM
sdetweil's Avatar
sdetweil
when I got my truck project, there were no running boards, but I have acquired two over the years..
The left one fits like a glove..
but the right one... when the existing bolt holes line up, there is about 2 inches between the board and the front fender, and there is a huge gap at the back edge of the cab, quite different than on the left side.
were there different board mount locations on different trucks?
I pulled both sets of hangers, sandblasted and painted them. and just now re-installed, almost two years later.. all the hangers look identical to me, so I doubt this is misinstalled hangers..
anyone have any other ideas to look at?
thanks
Sam
Old Apr 23, 2006 | 08:46 PM
jgurland's Avatar
jgurland
What year is the truck? Are the dimensions of the two running boards the same? On my truck ('53) there's supposed to be a gap between the running board and the front fender because there's a rubber spacer that goes there. It's about 1" thick.
What do you mean about the gap at the back of the cab? Does the running board reach the rear fender?
I agree that it's probably not a problem with your hangers. On my truck they are identical and there's only one set of holes where you can mount them to the frame. And if the holes in your running board match up with the holes in the hangers, then you've probably got it right.
Do you have any pictures of the right side?
Old Apr 23, 2006 | 09:03 PM
sdetweil's Avatar
sdetweil
55 truck. the distance from the back of the fender to the door edge is the same on both sides.
On the drivers side, there is a maybe 1/4 inch gap between the front edge of the board and the fender.. and the board mount holes line up perfectly, all 4 at once..
On the right side, if I use the front hanger holes, there is a nearly 2 inch space between the board and the fender.
If I use the read hanger hole, then there is a 3/4 inch space between the board and the fender edge.
there is a filler panel on the back inside edge of the board that goes to the bottom of the bed. This panel has a curved edge on it at the cab body.
On the drivers side there is a 1.5 in gap between the body and this curved edge. On the right side, when using the front hanger hole, there is a 3 inch gap. if I push the board forward so that it is 1/4 in away from the fender (like on the drivers side). none of the mount holes line up, but the curved panel is about 1.5 in away from the body..
almost like all four mount holes on the board are in the wrong places. oh, and I can do the two fronts or the two backs, but not all 4 as the holes don't line yup.
Yes, the hangers are in the only locations that bolts would go thru.
will take pictures..
Sam
Old Apr 23, 2006 | 09:16 PM
Randy Jack's Avatar
Randy Jack
I'm not sure what the cause of the problem is, but the fix seems obvious enough. You need to weld plug the old running board mounting holes and drill some new ones.
Have you matched the two running boards back-to-back? That might be interesting.
Old Apr 23, 2006 | 09:27 PM
jgurland's Avatar
jgurland
Randy, that's what I was getting at - only you said it better.
Sam, you need to make sure that the right side running board is the right size, and that the holes are in the right place. Before you get crazy, though, remember that there can be a lot of slop in those hangers. Before you start welding, loosen up the bolts where the hangers mount to the frame and try fitting your running board bolts in. Then get everything lined up and re-tighten the hanger bolts. You'd be surprised how much play there is there.
Old Apr 23, 2006 | 09:34 PM
sdetweil's Avatar
sdetweil
I haven't compared them side by side ( I 'assumed' that they would be the same).. which is why I was asking..
ran out of time in the garage today
Sam
Old Apr 24, 2006 | 12:44 AM
ALBUQ F-1's Avatar
ALBUQ F-1
The hangers on my 52 are not all identical -- I posted about this about 5 months ago and others were seeing the same thing. I don't know if 53-55's are the same. The front hangers point slightly forward at the outer end, the center ones are pointing almost perpendicular to the frame, the rear ones point to the rear slightly.If yours are like mine, putting them in the wrong places would account for what you are seeing.
Old Apr 24, 2006 | 06:25 AM
sdetweil's Avatar
sdetweil
Thanks, that was why I was asking. the 53-56 for sure only have two hangers per side.
Sam
Old Apr 24, 2006 | 08:24 AM
GreatNorthWoods's Avatar
GreatNorthWoods
Sam,
Flip that right one over and see if it has a sticker on it that says "Made in China". That might explain a lot...
Vern
Old Apr 24, 2006 | 09:17 AM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
Is this 1" rubber spacer between the front fender and the running board designed to take allow movement between the front sheet sheet metal (which as I undertand "floats") and the running boards (which are hard mounted)??
I wonder if the 48-52 trucks are similar
Bobby
Old Apr 24, 2006 | 09:27 AM
jgurland's Avatar
jgurland
Bobby
Good question, Bobby. I never really thought about it but given that the running board bolts directly to the rear fender (without a spacer) it's probably a good guess. At the same time, though, I don't think the front sheet metal floats completely, as the front fenders are hard bolted to the cowl.
Old Apr 24, 2006 | 09:36 AM
ALBUQ F-1's Avatar
ALBUQ F-1
The 1" rubber described is between the edge of the fender and the plate that fills in the gap between the front of the running board vertical edge and the fender (on 48-52's). (It is the fender welting). There is no rubber between the fender bottom and the running board horizontal surface.
I'm thinking of putting a piece of thin polyethylene between the running board and the fender, low friction and doesn't hold water (don't want my fiberglass to rust! )
Old Apr 24, 2006 | 10:37 PM
sdetweil's Avatar
sdetweil
Well, more info.. the running boards are identical in terms of where the mounting holes are cut. and when manually pushed forward to touch the front fender the measurements are the same as on the driver side. 7+1/8 to the front mount hole from the fender and 36+1/2 to the rear mount hole from the front fender..
too bad the hangers aren't there.
the outer hole on the front hanger is at 9 inches and the outer hole on the back hanger is at 37+1/4 inches from the front fender..
so for some reason these didn't mount nicely, or are slightly bent.. nothing I can tell when they are set on the floor side by side. I have no idea which ones came from where on the truck..
SO, it looks like I have to shim the trailing edges at the chassis to force the arm more forward.
weird..
Sam
sdetweil's Avatar
sdetweil
that sounds like a great idea..
Sam
Old Apr 24, 2006 | 11:49 PM
ALBUQ F-1's Avatar
ALBUQ F-1
It's pretty easy to pull the brackets fore and aft, they are strongest up-and-down. You can tweak them pretty easily.
